C63 AMG (W204) 2008 - 2015
What price are y'all seeing for replacement rotors?
Rating: Thread Rating: 3 votes, 5.00 average.
Old 01-12-2017, 09:59 AM
  #51
realjones88's Avatar
2012 C63 P31 sedan
Originally Posted by yazid
Question now is to either get OEM P30 replacements at a reasonable pricing or get a set of Racing Brakes' two piece rotor? Pricing isn't too far off though for the RB 2 pc rotor which is much lighter than the OEM P30 replacements.
If you are going to spend the money and keep the car, the Racing Brake could make more sense as the rings are replaceable so your next rotor set will be cheaper.
The regular $175 solid rotors also fit just fine. If you are looking to save some $$ or don't plan to keep the car I'd do this option.
yazid (01-12-2017)
Old 01-12-2017, 01:26 PM
  #52
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Whats the cost of the RB rings?
Old 01-12-2017, 03:03 PM
  #53
Former Vendor of MBWorld
RacingBrake's Avatar
CLS550
Front rings:
http://www.racingbrake.com/C63-AMG-F...405-01-381.htm
Rear rings:
http://www.racingbrake.com/C63-AMG-R...308-03-381.htm
Price includes brand new hardware, no extra cost.
Click "Replacement components" tab next to "Description" to access those links.
Unless you are tracking your C63, you probably never needs replacement. RB two piece rotors can last more than 100,000 miles for street driving.
Testimonial from an E63 owner:
https://mbworld.org/forums/w211-amg/...ml#post6830960
yazid (01-12-2017)
Old 01-17-2017, 09:01 AM
  #54
rif75's Avatar
BMW M4 + Bmw 335XI. Coming C63 2009
Originally Posted by Merc63
No there is a solid (Non-perf pkg) and 2 piece with aluminum hats which is on the perf pkg.
Hey guys
A lot of people told that the one piece rotor is ok for a C63 with performance package but the screw position on the rotors don't look the same to me.
Maybe there is 2 different position for left and right?
Can someone confirm for sure that it feat with no modification at all?
Old 01-17-2017, 05:35 PM
  #55
2012 C63 P31 sedan
They fit with no modifications.
Old 01-17-2017, 08:01 PM
  #56
BLKROKT's Avatar
Received 2,845 Likes on 1,678 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Those screws are not necessary. I know plenty of people who don't use them.
Old 01-17-2017, 08:59 PM
  #57
Jasonoff's Avatar
Received 1,598 Likes on 940 Posts
2010 C63 AMG
Hey guys
There is only one screw and it's in the exact same position in that pic you quoted. The 2nd hole is likely threaded used to work the rotor free once it has been stuck on the hub. The position of that hole doesn't matter.
Old 01-18-2017, 09:33 AM
  #58
mpowell's Avatar
2019 C63S Coupe
It looks like if you rotate the rotor clock wise that is lines right up.
Old 01-18-2017, 11:50 AM
  #59
rif75's Avatar
I though there were 2, why 2 hole if just one screw
Old 01-18-2017, 12:01 PM
  #60
Jasonoff's Avatar
2010 C63 AMG
Did you read what you quoted?
Old 01-18-2017, 02:33 PM
  #61
rif75's Avatar
I used my phone and didn t see the all answer sorry.
Old 04-14-2017, 11:47 PM
  #62
NeverSettle's Avatar
2012 C63 AMG DP
Tire Rack
Tire rack seems to have the one piece rotors pretty cheap. The photo is a stock photo of a solid rotor, but the description states:
(Front) Cross drilled vented rotor. 1 pc iron disc.
(Rear) Drilled & Slotted vented rotor.
My questions is - at 38k miles, i was told my rotors need replacing.
I have a 2012 C63 DP coupe.
Can I just buy Rings and pads and do the replacement - or do I need a whole kit, assuming I go with 2 piece. IOW - is the Factory setup Specific to Both parts needing to be replaced of the Rotor, or can replacement Rings be bought and installed on the Factory Hubs?
Thanks!
Old 04-14-2017, 11:57 PM
  #63
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Thanks!
Officially you cannot buy just the rings, but someone here was looking into having them fabricated. Otherwise you can just use the one piece rotors no problems. FCP Euro are great, plus they have a lifetime replacement warranty even on wear items. Unbelievable, but true. Unless they changed their policy. I replaced my 2 piece p30's with one piece, but kept the old ones just in case.
Old 04-16-2017, 06:44 PM
  #64
2012 C63 P31 sedan
You have to replace the entire rotor on a 2012 with PP brakes. The rings are not removable as they are forged '1.5' piece rotors, not true two piece. Yes the solid one works just fine if you want to save some $$.
Pics in this thread to see that thee are no screws to remove the rings:
https://mbworld.org/forums/suspensio...4210512-a.html
Old 04-19-2017, 01:36 PM
  #65
Veteran: Marine Corp
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
To eliminate any confusion, my set of 2 piece rotors, the ones of the right arrived yesterday, $798.00 delivered
Well........surprise, surprise!! I just pick up a pair of 2-piece rotors on eBay, guess how much? Wait for it......$798.00 Yes, that is for both front rotors. What a deal, because I've talked to my local MB dealer, and they want $$$$ Now AutohausAZ has the complete brake package for $2400, that includes (F)/(R) rotors, pads, sensors, retaining screws and brake paste.
Old 04-19-2017, 05:44 PM
  #66
2012 C63 P31 sedan
Great price, I didn't realize the P30 rotors had come down in price so much. Looks like FCP Euro has them for $490 each. Might have to consider picking up a set myself as opposed to $800 each for the p31 rotor. The Racing Brake ones are even lighter and $600 each, but include pads. Not a bad deal either imo.
Old 04-20-2017, 07:49 AM
  #67
Yuille36's Avatar
AutohausAZ
Well, AutohausAZ has the complete front brake kit for $2087, I thought that was a good deal considering the stealership price, but then I found them cheaper on ebay. But that doesn't include the pads, sensors or paste, but you do get the retaining screw.
Old 04-20-2017, 07:51 AM
  #68
Yuille36's Avatar
Keep in consideration that these parts of OEM, they also sell the Rear Kits for $378
Old 04-20-2017, 12:57 PM
  #69
Sick AF's Avatar
'12 C63 Coupe
If you want true 2-piece rotors, RacingBrake is the best option without a doubt.
Lighter and cheaper than OEM. I've had their kit in a shopping cart for the last 2 months...
http://www.racingbrake.com/Mercedes-.../mb-irk-18.htm
But after much debate, I've decided to go the cheaper route.
Ordered 1pc replacement rotors from FCP Euro
(2) front & (2) rear shipped for $543
Porterfield RS-4S pads from LPI Racing for $376
Total ~$1000 vs $2500
I don't doubt the benefits of unsprung/rotational weight savings, and I do plan on getting them down the road. But for right now, my car is a DD, and I'd rather apply that $1500 towards other goodies on my wish list.
Old 04-20-2017, 02:13 PM
  #70
MBNRG's Avatar
Arrow
If anyone is interested, am selling my P31 Brake Kit which includes everything except the Front Calipers:
http://www.ebay.com/itm/302279640607
Or come take a look in person. Price reduced if purchased via Paypal direct. Plz PM me with any questions.
Old 04-20-2017, 06:24 PM
  #71
2012 C63 P31 sedan
FCPEuro has the same thing for $1300 (add retaining screws for $10)
https://www.fcpeuro.com/products/mer...-w204amg2pfbk1
Old 04-20-2017, 07:47 PM
  #72
GRP
GRP's Avatar
2010 C63
I have used fcpeuro and their prices and shipping are both excellent. A good first stop for genuine parts.
Old 04-27-2018, 05:49 AM
  #73
clusterstudios's Avatar
C63
Old tread but I thought I'd try to post a question: I have a 2012 C63 that needs new front rotors (pads are good for now) and I'm wondering where I can buy some at a reasonable price online (Canada/US)? Also, is there any other part(s) I need besides the rotor when replacing the front rotors?
Thanks,
Old 04-27-2018, 08:19 AM
  #74
Yuille36's Avatar
Thanks,
You can buy the parts you need from multiple sources like; www.rockauto.com, www.autohausaz.com, https://www.mboemparts.com, https://www.oediscountparts.com,
Old 04-27-2018, 11:27 AM
  #75
C63
thanks so much....
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: What price are y'all seeing for replacement rotors?
