C63 black series wheels
2012 C63 coupe edition one
Hi all,
Does anyone know if the wheels on black series are/or will be available to purchase in the US ? If so, will they fit a 2012 c63 coupe?
Thank you!
Thank you!
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
i was hoping that would not be the case....bummer....b/c those are some pretty sweet looking wheels/rims!
thanks for the info...please keep me updated if you hear otherwise!!!
There are lots of "similar" wheels out there... 10 spoke forged wheels aren't hard to come by. Rennen has one (M10 I think), Nutek has one, Forgestar (although offsets aren't ideal). I think if you like the style, then there would be other routes you could go.
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
They are not forged to the same quality as HRE, etc. I believe they are rotary forged which is really like a very high end casting but I'm no expert. I also looked at the TSW wheels and the reason I backed away is that they are not hubcentric and need centering rings. I hate using centering rings as they are a pain in the butt IMO.
Well yea you cant compaire to something like HRE's but the TSW's are also very light weight and a huge difference in price between the two.
I must say I think they are one of the best bang for the buck light weight wheels out there.
2014 E550 4Matic with P1/LED/Pano
I have found the plastic centering rings tended to melt with track usage from the heat and the metal ones would seize to the hub like a spacer. Maybe I just had bad luck but just found them to be a pain.
www.arkym.com for info on the new J12 Wheels
http://www.flickr.com/photos/hrewheels/6786470114/http://www.flickr.com/photos/hrewheels/6786470114/ by http://www.flickr.com/people/hrewheels/, on Flickr
The Forgestar CF10 are a close match to these BS wheels in 19x8.5F and 19x9R. They will be semi-concave like the BS wheels as well. Ideal tire setup would be stock or 245/265.
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I believe our stock wheels are 19x8 +45mm offset, so the BS wheels at 19x9 + 25mm offset are too aggressive in terms they "might" stick out past the fenders a bit. But it's been done before, u will have to use a stretch tire to avoid rubbing.
The C63 and Black Series are completely different vehicles in terms of wheel fitment. The fenders are much wider. The rear of the Black uses a E-class rear end. The track/fitment are basically like 2 different vehicles.
Here you go with some pics
http://www.flickr.com/photos/hrewheels/7687866096/
http://www.flickr.com/photos/hrewheels/7687866552/
http://www.flickr.com/photos/hrewheels/7687865808/
