C63 AMG (W204) 2008 - 2015
Wheel Help?
Old 03-06-2012, 08:07 PM
sjhugh's Avatar
C63 AMG, BMW 135i
Originally Posted by C63 Pelican
Care to explain? From what I heard earlier 45-50 offset would in fact work with a 9.5 rear
A +50 offset would most likely work but they are offering the VMR 718 only as a 19x9.5 with Offsets of ET33 or 45. That’s aggressive when you intend to lower the rear 1.2 inches and unless you want it to rub on the bracket where the fender and rear bar meets, you‘ll need to run a skinny tyre with that combo with still the likelihood of rubbing when you have passengers. Wide rims and skinny tyres, what’s the point? For the sake of a less aggressive Offset, you can get more rubber on the road.
Old 03-06-2012, 09:10 PM
Strafe1's Avatar
2021 E63 S Sedan
With a large selection of great looking wheels out there, I would find a wheel with more ideal offsets. This would be better than working at the limits. Get a wheel with a better offset and put on lots of rubber and get the best of everything....aggressive look and aggressive grip.
Quick Reply: Wheel Help?
