C63 AMG (W204) 2008 - 2015
Widen Rear Stock Wheels?
Old Mar 10, 2012 | 10:42 PM
cbluerock's Avatar
2010 c63 AMG
Hey guys,
I have a CL63 2010 AMG and was wondering if anyone has widened their stock rear wheels?
I wanted to keep the stock look, but wanted to move to a 10.5 or 11" wheel so I can run a 295 series tire for more grip.
Has anyone widened them or knows a good place that does? And what's the widest wheel we can add without rubbing?
Thanks /Craig
Old Mar 10, 2012 | 11:09 PM
andrew c230k's Avatar
W204 C63 R171
I don't think you will be able to run 10.5 or 11" wide rims on the rear of a C63
I just bought some 10" wide rims with an offset of 60 they hit the inner fender and manufacture supplies a 5mm spacer to give it proper spacing. I am going to run 275 wide rubber on it.
Stock width is 9" on a C63 and on other W204 Platforms is less.
Old Mar 10, 2012 | 11:13 PM
cbluerock's Avatar
2010 c63 AMG
Thanks.
Is is possible to run a 265 or 275/35/18 on the rear wheels?
Old Mar 10, 2012 | 11:18 PM
W204 C63 R171
When you add a wider tire to the same size rim it will raise the car up in the rear and give you odd tread-ware and rake towards the front...
Stock is 255 I know several people that used 265... 275 is recommended to run on 8.5"-10" but it will depend on your application
Old Mar 10, 2012 | 11:20 PM
W204 C63 R171
oh BTW are you talking about a CLS63 or C63 ???
Old Mar 10, 2012 | 11:31 PM
cbluerock's Avatar
2010 c63 AMG
I meant C63, I just purchased a 2010 w/ 9K miles on it. Absolutely amazing ride.
