Confused about the head bolt issue
And, while it's there, consider increasing performance (but not required).http://weistec.com/all/c/c-63/2012-2...internals.html
Seriously, you already have one thread started on this and there are literally a hundred others. Now you revive a 3yr old thread.
I swear this place lately is like the inmates running the asylum smh...
EDIT: CLICK HERE (if it's not obvious, this is the 3rd sticky from the top) ------>https://mbworld.org/forums/c63-amg-w...-problems.html
*If you have a "low coolant" warning come on the dash - READ THIS*
head stud install
Had multiple warnings come up on dash
Opinions needed on Headbolt replacement
C63 AMG 2009 Two broken head bolts
2011 with bad headbolts
Research on headbolt failure
Weistec Stage 3 build w/ replacing head bolts thread.
Bad news after 1 month!! Cel, check coolant, smoke!
Loosing Coolant Like Crazy
Not Another Headbolt Coolant Issue!
C63 Head Bolts and Engine Repair
Coolant usage-may be the "bad news"
Coolant leak
2010 C63 P31: Porous Aluminum Head, Leak in Bottom Plate, & Bad Head Bolts
C63 guys-check this out.
Serious problems with my C63. Help !
-----> Head Bolt Affected VIN - 2010 & older, & early 2011s
-----> DIY: Head bolt swap on M156.
This head bolt issue is interesting.
I have an XJS v12 and to stop any corrosion issues with head bolts I use water less coolant.
http://liquidintelligence.com.au/
This may be worth considering?
I have had a number of issues over the years: intake manifold problem, oil leak at the block, air suspension pump failure, fuel pump failure, but not the bolts (knock on wood…).
I asked my SA, and he said, of all the many many m156 engines that they've had come through their busy dealership, bolt failure has only been seen on a handful over his last five years there.
Seems to be low incidence.
Still in the back on my mind…78K miles.
