Air Conditioning Not Working
W204 C63 R171
The Air conditioning on my 2008 C63 is not working properly, I checked the fuse today its fine... the compressor clutch is not working as far as I can tell so its either low, or someone knocked the wire off. Any other tips or things I can check before going to the dealer.
I also don't have my manual so if there is some special procedure for turning on the the A/C let me know.
There is an A/C button on the climate control that should illuminate red when on. I believe if there is a malfunction with the compressor it will flash or not come on at all
W204 C63 R171
Its red and lit up solid all the time... I just too a look at the compressor from under the car as far as I can tell its all plugged in but i cant tell if the compressor is running or not the pulley is turning but the lines aren't getting cold or hot... I am going to connect the computer up to see if there is any codes and maybe a pressure gauge to the system to see if it has a leak.
