Finally in the HRE family :)
btw, thanks for the tip on the Rear spring pads. Just got my H&R springs installed yesterday and the drop looks really even!
Noodleman, I'm glad u like the look of the H&R springs with the thicker pads. And what model Works did u get? Avengerboater car was so nice on Work vsxx.. I'm sure they will be worth the wait.
I also wants to use my oem lugs as i trust the oem ones more than some china made lugs. Did you have to buy an extended socket or the holes in the HRE are large enough to install the lugs with ease?
Post pics of ur set-up here.. And can u tell me ur exact full set-up that u r running (I know u mentionned the rear). Thx again!
Lets see how we do this. O ya sell the stock 18" OEM 5 spoke to buy 19" 16V AMG. 19" pulled off market leaving you stuck for spring/fall/winter storage wheels.
Post on MBWorld looking for 19"AMG wheels. None around except the new ones from England. Talk the new wife (congrats
) into buying a new set from the dealer because they will be about the same as the ones from England by the time they are landed in Ottawa.
Let a friend twist your arm into a well priced set of HRE P40 from Wheels Boutique. Way to go jakio!
Which set you going to let the car sit on for the spring/fall/winter storage? Need to buy another set of OEM 18" AMG or some 19" 16V AMG?
Guys this is how you get a new set of HRE P40 past the guardian.
Good job Meng. In the pink!
Exactly the story of my life.. Sucks to be me, huh? Lol
Now that I have 2 fancy wheels set, and still no OEM.. I guess I wi have to park my car on blocks this winter.
You made the right choice on the tire brand and sizes.
BTW, can u comment on my sizing? Do HRE makes +55mm offset? Thx
Not sure about your sizing, I let Andre from Wheels Boutique look after mine.
My offsets on rear
20 X 9.5" ET 51
My SV1 set is 19x8.5 (235/35) +45mm, but they are not flush. So I'm thinking 19x9 (245/35) this time, but not sure if the handling will be affected?
I was recommended by HRE: 19x8.5f + 41mm with 245/35/19 & 19x10 +50mm with 275/30/19.
Can someone tell me the difference (how many mm more does it stick out from oem wheels) between the set-up recommended & my previous set-up of 19x9 +45mm & 19x10 +55mm?
For the rims them selfs, the fronts will stick out 2.35mm more & the rear will stick out 5mm more.
Now, decision decision.. Is 5mm enough to make it rub?
My final choice is 19x8.5f +41mm & 19x9.5r +50mm as recommended by HRE. Anyone running this exact same size can chime in about flushness & not rubbing? Thx
