C63 AMG (W204) 2008 - 2015
M156 head bolt problems
Rating: Thread Rating: 3 votes, 5.00 average.
Old 08-26-2015, 09:09 PM
  #926
Cody D's Avatar
2012 C63 AMG
Originally Posted by Mort
I have not heard of any FL (LCI) cars with head bolt issues. It is not unusual to have the coolant go down a little over time. It happened to our R Class diesel quite a few times and to my 2010 C63 a couple of times with no other issues.
I always recommend adding a 50/50 mix of distilled water and MB coolant in the same colour that is in your cooling system. This will maintain the properties of the OEM coolant in your engine which is 240,000 km or 15 years. If you add straight water (distilled or not) or other brands of coolant this coolant change interval is no longer valid and the coolant should be changed much sooner.
Awesome, thanks for the information. I am going to bring it in to the dealership next week and just let them go over it.
Old 08-29-2015, 09:04 AM
  #927
peckcrossing's Avatar
2009 C63: <sold> '07 E63
I may be the next in line with headbolt issues. Started the car yesterday afternoon and it had a different sound. Left work and drove home (60 miles) and three miles from home I get the low coolant level warning. Drove right to MB and of course almost everyone was gone. They did add coolant saying it was half full and told me to come back Wednesday. I'm not moving the car until I take it in. Should I use an Indy or the MB dealer?
Old 08-30-2015, 12:35 AM
  #928
Missionary's Avatar
C63 2012 M156
Hi folks, trying to get a little clarity here.
Were the head bolt AND the combination of cast nodular iron camshafts and 9310 grade steel valve lifters issue both resolved post engine number #60658?
My engine number is 72157 so does that mean it definitely has the forged camshafts?
Was the lifter metallurgy changed at the same time as well?
S-B 05.20/20b mentions issues with the camshaft adjusters.
Do we know if MB ever made any changes to these or is the issue with them due to the soft cast camshafts rather than the camshaft adjusters them selves?
Anyway to tell if my motor has forged camshafts without pulling the valve covers off?
Old 09-02-2015, 12:30 AM
  #929
MountainStone's Avatar
02 C32
If the headbolts and lifters are replaced, will the M156 live a long and happy life? Is there any way to determine whether a particular car has had the headbolts and lifters replaced?
Old 09-09-2015, 03:32 AM
  #930
Tyler Ornstein's Avatar
W211 E 55 AMG
when should I replace my coolant tank
Old 09-18-2015, 06:09 PM
  #931
trvlnut's Avatar
ML320
Hi:
Would someone check these VINs?
WDDGF7HB5BF587748
WDDGF77X69F246981
Old 09-18-2015, 09:58 PM
  #932
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by trvlnut
Hi:
WDDGF7HB5BF587748
WDDGF77X69F246981
All 2010 and older and some early 2011s are affected. The 748 is not and the 981 is affected.
Regards,
Joe
Old 09-19-2015, 03:04 AM
  #933
mikelin7's Avatar
'86 190E, '93 CAMRY V6 XLE, '94 626-LXV6, '96 328is, '09 C350
Hi
Could anyone check VINs for me?
WDDGF7HB3BF567014
Old 09-19-2015, 08:25 AM
  #934
Euler's Avatar
2008 C63, 2008 ML550, 2014 KTM 500 XC W, John Deere 990
To all you that changed out your head bolts one at a time, did anyone experience a snapped bolt in the process and have to pull the head off? I'm pulling the trigger on Weistec parts and doing the replacement myself. I'm at 45K miles and the head bolt thing is starting to eat into my driving enjoyment.
Old 09-19-2015, 09:05 AM
  #935
Valvestud's Avatar
Originally Posted by mikelin7
Hi
WDDGF7HB3BF567014
Not affected.
Regards,
Joe
Old 09-19-2015, 09:07 PM
  #936
Boost Inside's Avatar
C63 AMG 2009
Hi
WDDGF77X09F205214.
Thanks.
Old 09-19-2015, 10:42 PM
  #937
Jasonoff's Avatar
Received 1,594 Likes on 938 Posts
2010 C63 AMG
Originally Posted by Boost Inside
Hi
WDDGF77X09F205214.
Thanks.
It's an 09, there's nothing to check...
Old 09-20-2015, 09:33 AM
  #938
andya34's Avatar
AQUIRED A C63 AMG PPP
do p30 cars 2010ppp get affected?
Old 09-20-2015, 10:15 AM
  #939
Valvestud's Avatar
Correct.
Old 09-20-2015, 09:17 PM
  #940
C63 AMG 2009
Thank you.
Old 09-21-2015, 01:39 PM
  #941
Euler's Avatar
What are the torque values for the cam bearing caps?
Old 09-21-2015, 01:43 PM
  #942
Euler's Avatar
To the folks that have had the failure. Is coolant getting by the head gasket and into the cylinder or is it flowing up around the broken bolt into the cam gallery then mixing with oil or both.
Old 09-24-2015, 12:42 AM
  #943
Merc63's Avatar
C63 AMG
The head bolts pass through the water jacket. The bolts have a bit of sealant on the head that seals coolant into the block.
Old 09-28-2015, 08:35 AM
  #944
Celicasaur's Avatar
W212 - E63 AMG
For what it's worth, mine is a 2010 E63 (UK/Euro model) and I checked the headbolts last weekend - happy to report that they're the revised ones.
And for good measure, the part number for the VVT gear
I'm not sure if it was done by a previous owner etc. I tried looking for the engine number down the back of the engine bay, but lost patience after 20 seconds of trying to get the right angle down there with my flash light.
Old 09-28-2015, 08:16 PM
  #945
Jasonoff's Avatar
2010 C63 AMG
You know you can get your engine number from the VIN right?
Old 09-28-2015, 09:27 PM
  #946
Valvestud's Avatar
Just post or PM your VIN number and I'll give you the engine number.
Old 09-29-2015, 04:41 AM
  #947
Celicasaur's Avatar
W212 - E63 AMG
Yeah no, I felt bad and didn't want to trouble that Valve guy, so just figured I'd not ask
Thanks man, I will do
Old 09-30-2015, 06:56 AM
  #948
Celicasaur's Avatar
W212 - E63 AMG
Valvestud kindly confirmed my engine number to be:
156985 60 062884
Does this mean the vvti cam adjusters and cams are the revised ones too, or is it just a headbolt difference?
Old 09-30-2015, 05:52 PM
  #949
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
156985 60 062884
It's strange that '10 cars in UK already have the updated head bolts, but almost all '10 and early '11 cars in the US have the old head bolts. What month and year was your car built?
Old 09-30-2015, 06:39 PM
  #950
2008AMG63's Avatar
2008 E63, KTM990, 2012 CLS63, 1972 W108 280SE 4.5
Originally Posted by ML63Italy
Just wanted to update on this issue. In the end, nobody did step up to assist, I did receive a 10% on the parts (total price for parts came to a cool 4,300 euros). The end price came out to be around $6,500. Now for something interesting: All was fixed and car runs well, no issues, expect..... over the course of the last 8 days the engine had made a very disturbing rattling noise when I turn it on. The noise (clack clack clack type) subsides after 3-4 seconds. Cannot say it happens only when the engine is cold or hot, as it has happens with both. garage tells me that the valve shafts will need about 600 miles until they are seated and that this is nothing to worry about. Well I am worried...Strange thing is that I cannot reproduce the noise by turning the car on / off. it just seems to happen arbitrarily. Any thoughts?
I had the clack, clak ... they replaced tapets.
The noise is back and I found that the oil level was low.
Check your oil level
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: M156 head bolt problems
