2012 MCT....Changing settings while driving
When I had my 09 C63 I was able to change the transmission settings while driving, even into and out of manual mode. I don't know what the manual said in regards to this, but there was never a problem doing it.
Does anyone know if it is safe to do this in the 2012? The manual says not to, but does anyone have any info on if there is real damage potential? |
You read the manual? I didn't know you couldn't change it on the fly. Meh I leave it in C 90% of the time anyway.
:eek:WHAT!? cant change it on the fly?
I do this all the time:wwf: I dont see what could be wrong... |
It is an electronic transmission in a sense that there is no requirement to stop the car, you are allowed to and it was designed for this.
yes. this warning in the manual is unfounded. i do it all the time.....no problems. if it was harmful......there would be a safety function that would force you to stop to change modes.
its just one of the dumbest things i have ever read in an automobile manual. all it is, is an electronic change is shifting logic. i wouldnt floor it and change modes but any other situation.....go for it. |
Originally Posted by CELLryuu
(Post 5192425)
its just one of the dumbest things i have ever read in an automobile manual. all it is, is an electronic change is shifting logic. i wouldnt floor it and change modes but any other situation.....go for it. like trying to key in an address on the navi while the car is in motion |
Originally Posted by bluejae
(Post 5192436)
+1
Originally Posted by balthaser
(Post 5192534)
talking about this, any way to bypass this limit?
I change mine when I'm at a consistent speed and throttle so it doesn't try anything funny mid-shift. Seems pretty safe to me.
Originally Posted by TEKZILLA
(Post 5192555)
(Post 5192558)
i always change mine with my foot off the throttle.. so after changing, it can change to whatever gears it needs to on it's own... then back on the throttle
I'd also avoid changing it from C to S at crawling speed as you may get a clunk as it changes back to 1st. I always make sure I've come to a complete stop when I do this.
The book only says to stop the car when going into MANUAL Mode. I never did this in my 09, and by the responses so far, it seems OK to do it with the upgraded tranny.
The tranny is electronically controlled. If it would damage the transmission in any way... even going into M... the car would not allow you to switch modes. It would be very simple for MB to limit the ability to change modes if they wanted or if needed. They wouldn't allow you to do this if it would damage the car becauce a huge majority of C63 owners would never read or see this in the manual and they would be getting broken tranny's all the time :D
Nothing will happen. 10k km behind and nothing.
I have done it since the first kilometer and have never had a problem. Mine is a 2012 sedan.
No issues except for when I did it while I was flooring it -it wouldn't accelerate. Took my foot off the gas, reapplied 1 sec later and everything was back to normal. In any given drive Im always going back and forth because I feel really guilty keeping it in M all the time.
Originally Posted by VaclavSV
(Post 5192924)
(Post 5192558)
(Post 5192436)
+1
The manual says you can switch from C to S to S+ while driving. Only when stopped can you/should you switch to M mode.
I haven't tried.... And I won't... Just in case. |
