Removing Wheels on my 2012 C63?
The change in tyre pressure in Australian spec cars and I think for Euro spec as well is monitored by the ABS system for memory.
The setup for this system is in the dash cluster menu and has to be done every time a wheel is removed.
I’ve done mine a few times.
http://www.slime.com/shop/category/p.../smart-spairs/
I've also looked at the jack pads you mentioned, from the same supplier. So these sit on top of my trolley jack & enable me to lift via the factory jack points, because this device slots into the factory jack location? Is that correct? For your C63 did you order part no, "W204Plus"?
Thanks again, Pickles.
and
Two JSA_M Jack Stand Adapter for MB (Come in pairs)
Because I work from the floor I need the Jack Pad Tool to get the lift started and then switch to the Jack Stand Adapters for use with the jack stands I use. If you use a hoist then you might want four Jack Pad Tools. The Jack Pad Tool fits in the jack point fitting on the car and is held in place with pins built into it. You then jack on the Jack Pad Tool.
I have the M14x1.5-SS Stainless Steel Lug BOLT Guide Tool and these are correct for the C63.
and
So after you jack it up using one of the four corner jack points using the jack pad, where do you place the jack stands? This is my first Merc and I don't want to take any chances!
