Radar detector mounts
Has anyone found a mirror mount that will work with a radar detector? I see a few of them on the market but one specifically says it won't work with mercedes... Another doesn't mention....
How are you guys mounting your detectors? The suction cups just won't work for me anymore and tend to fall off a few a few days due to the heat. And I don't want to spend the money for a built in detector since I never keep a car more than a few years.
I think escort has a bigger "super cup" that works better. Mine falls off a lot too. I would recommend cleaning it with alcohol too. It seems to gather moisture in the area it sucks onto some how.
2007 E350, 2010 C300, 2008 R350
That said, I was also looking for a stealthy/mirror mount setup, and the super cup doesn't let you tuck the detector in close to the windshield, which os a problem by the mirror due to the need for sky-visibility for the GPS function to work.
Solution: There is a modification for the super cup mount that I did involving changing the angle of the tab. I found the modification on a radar forum. i will try to find a link, and if wanted I could post pics of my set up.
