PARTING OUT ENTIRE 2009 C63!!
Subscribe
Oct 8, 2015 | 10:42 AM
  #326
Quote: What do I need to replace if this is the problem? The whole pump assembly?
That is what the dealer does. It may be covered under warranty or goodwill. Worth asking. I have not had one apart but had one replaced in our GLK 350 under warranty. It is a known issue. Once they start to leak replacement may be the best repair. Does it only go down so far and stop? Fill it up with water and see if you get a puddle in front of the driver's side tire that stops before the tank is empty. Then it likely is the seal around the tubes that go in to heat the washer fluid. Not sure of any other repair options.
Reply 0
Oct 9, 2015 | 06:15 AM
  #327
Quote: That is what the dealer does. It may be covered under warranty or goodwill. Worth asking. I have not had one apart but had one replaced in our GLK 350 under warranty. It is a known issue. Once they start to leak replacement may be the best repair. Does it only go down so far and stop? Fill it up with water and see if you get a puddle in front of the driver's side tire that stops before the tank is empty. Then it likely is the seal around the tubes that go in to heat the washer fluid. Not sure of any other repair options.
Yup, just tested it out today. There's a puddle by that side of the car.
The tank is also not completely empty either too, as I can still spray fluid when it tells me to "Refill"
Reply 0
Oct 9, 2015 | 01:57 PM
  #328
Quote: Yes I have it
pm me price shipped to 77521
Reply 0
Nov 11, 2015 | 04:35 PM
  #329
Do you have the calipers and rotors still? If so PM me please. I'm in Texas.
Reply 0
Nov 11, 2015 | 05:25 PM
  #330
Sold
Reply 0
Nov 14, 2015 | 02:38 AM
  #331
do you have any parts remaining? im looking for the trunk badges and the center dash speaker
Reply 0
Nov 14, 2015 | 02:39 AM
  #332
That's all sold now sorry. There is almost a couple pages back of what is left.
Reply 0
Nov 14, 2015 | 08:01 AM
  #333
Still have intact center console / armrest cup holders ? Plastic spring bar broke on mine
Reply 0
Explore
Nov 14, 2015 | 09:59 AM
  #334
Yep I have that
Reply 0
Nov 22, 2015 | 01:32 PM
  #335
Looking for one of the rear seat belt buckles, the one for the rear center belt. Let me know if you have it. Thanks
Reply 0
Nov 23, 2015 | 11:07 AM
  #336
Merc
What the chances u have stock diff?
Reply 0
Nov 23, 2015 | 11:17 AM
  #337
Sorry I don't have it.
Reply 0
Nov 23, 2015 | 11:53 AM
  #338
Quote: Sorry I don't have it.
TY
Reply 0
Feb 1, 2016 | 10:01 AM
  #339
very interested in the c63 mufflers... PM me if you're still parting this beast out
Reply 0
May 1, 2016 | 03:39 PM
  #340
regular leather shifter boot ?
maf sensor plastic covers ?
engine cover metal clips (as many as you have) ?
tow hook cover from front (if your car was black) ?
Reply 0
May 1, 2016 | 09:43 PM
  #341
I have the leather shifter boot and MAF sensor plastic covers
Reply 0
May 1, 2016 | 09:54 PM
  #342
Quote: I have the leather shifter boot and MAF sensor plastic covers
cool. how much ?
Reply 0
May 1, 2016 | 10:16 PM
  #343
50% retail
Reply 0
May 2, 2016 | 07:12 AM
  #344
trunk cargo clips?
(the plastic clips near the access panels)
I'll take both sides if you have them.
Reply 0
May 2, 2016 | 09:03 AM
  #345
No have
Reply 0
Jun 28, 2016 | 06:31 PM
  #346
Do you have these pieces?
- Trunk lining/carpet piece that goes over the spare wheel & battery
- Battery fastener, rail, mounting piece to hold the factory battery down (all pieces)
- This radiator plastic piece. Plastic piece sits on top of radiator support, helps hold up the front grill. A2048850336
Thanks.
Reply 0
Jul 11, 2016 | 12:58 AM
  #347
Do you still have a hood for sale.
Reply 0
Aug 4, 2016 | 08:36 AM
  #348
Do you happen to have the driver's door panel still? I am looking for one with the stainless trim.
Thanks!
Donny
Reply 0
Aug 4, 2016 | 08:57 AM
  #349
Doesn't have stainless trim
Reply 0
Sep 10, 2016 | 09:41 PM
  #350
Do you have the vacuum rubber hose that goes into the Y intake piece, it's part of the emission system?
A1560700938
Aluminum Cross Rail - Radiator Support + bolts?
A2046205234
Any of these?
Reply 0
