C63 Coupe cracked rear 19inch alloys HELPPP!!!
Check on a repairs wheel in internet from your service area you will find and they would fix it for about 100 each
What exactly is this disaster you're speaking of? Are we talking about the wheel exploding into fragments, losing control of the car, and crashing into imminent death? The only disaster I can foresee for such a "fix" is another crack near or around the weld area, resulting in the original problem. A slow and barely noticeable air leak, which may or may not result in another flat tire. I honestly think the chances of getting killed by a drunk driver far outweigh the chances of wrecking over an exploding rim due to negligent welding. By that logic we probably shouldn't even be driving on the road in the first place. Either way I did my research, I consulted with the right people, I fixed it, saved a $1000, and so far, so good.
As said before, there is always wheel insurance, and people who think its worth the price gladly pay for it.
There are so many problems with the first part of your statement that I am not going to address it here. There are plenty of resources on the Internet that you can consult that should convince you that welding a cracked or broken alloy rim is a bad idea for a number of reasons (Google "stress fractures in welded aluminum alloys"), but if you've already made up your mind there is no point in either one of us wasting time here. Overall principles with he same core elements are responsible for making up everything in the universe, and certifying a wheel has nothing to do with repairing it.
A sudden tire blowout (if the rim section that was repaired gives way around the repair weld, which is not unusual) can easily cause you to lose control of the vehicle. What happens after that depends on a large number of factors, but if you Google "ford explorer firestone tire recall" it might give you a general idea. Too bad no one from Ford thought of using the "hit by drunk driver vs. tire failure probability" statistic in their defense - you could have saved them millions if you had told them of this at the time of the lawsuit.
I am not debating the merits of wheel insurance, only the merits of welding cracks in your wheels. Yes, there already is enough danger on the roads from intoxicated and distracted drivers. Why would you knowingly increase that risk yourself by performing a cheap, improper repair on a critical part of your car?
