Brake fluid flush??
#51
Kind of / sort of on topic: I noticed during my track event this Saturday that my pass-side front caliper turned burgundy/maroon color whereas the driver'-side front was still pretty close to the original Brembo red (maybe just a tad darker)... The brakes were never smoking or anything nor did I notice the car pulling to one side or the other, so I'm guessing that the P-side just got hotter than the other and the D-side will eventually turn that color too? Or is there may be a mechanical issue in the PS caliper like a sticking piston that caused that?
Either way, I'm sure I cooked the fluid on that side and I should re-bleed again... Just wondering if the fluid I left in my Motive bleeder a few weeks ago is still good
#52
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Brake fluid is good for a few weeks if sealed tightly. Not sure if I’d trust the Motive with all that excess air volume.
Caliper discoloration is a strange thing. Wobble64 turned his caliper paint to dark reddish grey after just a few track days. On the other hand mine are still Brembo Red after 4 years of heavy track duty. And I’m not easy on them - my wheels have been so hot that they melted the center caps. I don’t know why some discolor while others do not but I wouldn’t worry about if if the brakes are performing fine.
EDIT: Took my calipers off to refinish. After cleaning them up I can see that the paint is discolored. Dark and light patches everywhere. And all of the dust boots were trashed.
#53
FWIW, I lost two front center caps from my Forgelines this weekend too... melted the o-rings and found themselves a new home somewhere at Homestead Miami Speedway
#54
The fluid left in the motive would been fully exposed to external atmosphere unless you blocked the end of the tubing and kept it pressurised.
That fluid is junk now.
#55
Wasn't much in there anyway, so I'll just throw that out a toss a fresh pint in there... Should be enough to at least get the calipers and SS lines cleared. Stuff in the reservoir is pretty new and should still be good enough to push through the system.
