C63 AMG (W204) 2008 - 2015
need alignment?
Old Oct 13, 2012 | 09:48 AM
Paculdo's Avatar
06 CTT-S
need alignment?
do i need an alignment if i lower the car on stock wheels?
Old Oct 13, 2012 | 12:17 PM
Mort's Avatar
Yes it is a good idea to get an alignment after lowering your car. You can have the toe-in adjusted to spec and if you want camber bolts installed on the front to reduce the negative camber. You should also get a print out showing the current settings for camber and caster and how they compare to stock settings. If you are installing coil-overs the car can also be corner balanced for best performance.
Old Oct 13, 2012 | 02:37 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
An alignment is always recommended any time you mess with the wheels.
Old Oct 13, 2012 | 03:28 PM
Paculdo's Avatar
06 CTT-S
thanks guys!
