C63 AMG (W204) 2008 - 2015
OE Tuning tunes my C63 Black Series with before and after dyno results inside!!
Old 02-04-2013, 09:00 PM
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question
Originally Posted by TTA850
First off, nice power stock and tuned. I havent had a chance to dyno or tune mine yet but hopefully when the salt is all gone lol
As for part numbers a quick look on the EPC says the crank (1590300001), rods (1590300020), and pistons (1590300217) are the same between the P31, BS, and SLS. I didnt check the standard C63.
The heads (1560108820 & 1560108920) are the same between the P31 and BS but the SLS has different heads (1590100020 & 1590100120). The intakes (1561410901) and cams (1560504201, 1560504301, 1560504401, 1560504501) are the same between P31 and BS but the SLS uses different cams (1590500601, 1590500701, 1590500801, 1590500901). Interestingly though they all use different blocks 1560109900 for the P31, 1560109800 for the BS, and 1590100600 for the SLS.
I'd love to know the lift and duration differences between the C63 cams and SLS cams because they run around $2550-2750 a set and from what the EPC says the C63 uses the same part number valve tappet (1560500225) ,at least my '13 P31 car does and they are around $520 a set. I also wonder what if any flow differences there are in the heads, they are more cost prohibative at over $5K a set.
Anyway I hope the part numbers are correct and clear some questions up
TTA850....Good solid info there mate.
I reckon that the ECUs would have different numbers, and maybe the exhaust manifolds for BS & P31 would be different. Any chance of checking those two items (ECU & Exhaust) for P31 & BS?!
Cheers, Pickles.
Old 02-04-2013, 09:35 PM
TTA850's Avatar
2015 E63S AMG & 2013 GLK350
Cheers, Pickles.
No problem, interesting results actually. The PCM's carry the same part number (1569003000) because the differences are in the actual program. The exhaust manifolds (1561400009 & 1561400109) and the cats (2044901047 & 2044901147) are the same in both P31 and BS but the cat back pipes are different. 2044900860 and 2044900960 for the BS which btw does not come with tips, the tips are actually considered part of the bumper from what I understand part numbers 2314900127 and 2314900227. The P31 cars come with 2044903521 and 2044903621 which has tips on it.
Old 02-04-2013, 10:14 PM
Pickles's Avatar
Thumbs up
AWESOME info mate. I thought the exhaust manifolds may have been different.....just shows how good all these items are.
So, it's fair to say that P31 & B.S. engines are the same, except for the tune?
Thanks, Pickles.
Old 02-04-2013, 10:25 PM
Jason Anthony's Avatar
2013 C63 AMG Coupe
well that's strange considering i had my p31 coupe tuned by the same people and came out with far less power. what's up with that?
Old 02-04-2013, 10:32 PM
Guilty's Avatar
'16 C63-S
Your car needs Redbull
Old 02-04-2013, 10:50 PM
Even Money's Avatar
'15 VW GTI
The crankcase is different in the black in that it doesn't have the vent holes between cylinders, whereas the P31/non P31 block does.
Old 02-05-2013, 01:17 AM
  #32
vdubpower's Avatar
i drive them all, fast and hard
vic , took a while but finally a tune
your dynojet numbers with tom are around 460 or so right, so it seems the pre tune dyno dynamics is pretty close to the other dyno.....i wonder what the numbers would be at eas post tune....
besides that, how does it drive differently, is the change significant like with the TT cars, or more subtle
Old 02-05-2013, 10:48 AM
  #33
Administrator
Vic55's Avatar
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Great question--- it wasnt like your car was done on a different day. When I got there your numbers were still on the screen- I had just missed you.
I like dynos for perspective and for tuning they are a tangible way to measure what was done right then and there but my favorite dyno is the street dyno.
Old 02-05-2013, 10:51 AM
  #34
Administrator
Vic55's Avatar
NO chance does it change like a turbo tune--- its subtle but noticeable. The car jumps more in lower gears and up top it pulls harder but its only noticeable because Ive driven my car enough. 20hp net at the wheels is not huge but its a gain none the less. My car at Tom's (EAS) dyno'd 451 at the wheels so its relatively close. The car is strong no doubt and I broke it driving it the right way; hard up and down the rpm ranges to push the seals out. Im not sure if this helped my numbers but I do believe in the "hard break in" method versus the pampering that is often advised off the dealer lot.
Old 02-05-2013, 11:35 AM
  #35
Ezec63's Avatar
C63 Coupe
Vic first of all great number your car is running strong !!
i couldnt agree more on the break in procedure buddy. I mean have you seen what AMG does in the factory before they send there engines out haha i never got the whole baby your car to a certain mileage. I did a burnout out WOT redline shift right out the dealership haha but i agree that it helps everything seat to the maximum potential. The black series seems to run strong ! I have a non p31 coupe that a drove the t1ts off for 2000 miles than added EC Tune, Evosport UD Pulley, and TTM Airbox(like ROW) with BMC filter and charcoal delete. I put down from 460 on a run where timing was pulled to best of 474 so we have very similar numbers but you dont have the UD pulley i guess those lighter internals are worth something after all ! Currently have the car in for secondary cat delete and going to re dyno. I will try to attach dyno sheets
OE Tuning tunes my C63 Black Series with before and after dyno results inside!!-dyno2_zpsa5b1b22a.jpg
  #36
Ezec63's Avatar
C63 Coupe
OE Tuning tunes my C63 Black Series with before and after dyno results inside!!-dyno1_zps4d3c4f68.jpg
Old 02-05-2013, 11:36 AM
  #37
vdubpower's Avatar
yeah i dunno, i pampered mine, and i got 501/536 to the wheels,
what did your TT's lay down before the tunes ?
Old 02-05-2013, 12:28 PM
  #38
Administrator
Vic55's Avatar
Close to yours...510hp I think on a DD dyno.
Quick Reply: OE Tuning tunes my C63 Black Series with before and after dyno results inside!!
