Detail writeup on my car (for anyone interested)
through buffing, he removed some of the surface of the clear coat, leveling the clear coat so the bottom of the scratches that were present are now level with the rest of the clear coat, essentially removing the scratches and revealing basically a fresh surface of clear coat. however, this removes clear coat material and makes the clear coat slightly thinner. to give you an idea, the whole paint system on your car (primer, base coat (color) and clear coat) is about the thickness of a Post-It note!
but, Wes is an expert and takes measurements to assure that he's removing JUST enough to remove the scratches but not compromise the clear coat in any way. clear that is too thin will fail early because it doesn't have enough material to handle UV, heat, damage from bird bombs, hard water, etc. measurements help prevent this. if a scratch is too deep, often times an expert like Wes will leave it since it's not worth the chance of making the clear too thin JUST to totally remove a deep scratch.
but yeah, the scratches will come back if improper washing/drying techniques are used. this includes brushes, dry wiping, hard wiping, poor/dirty wash media, dirty wash solution, etc. other types of damage can occur if bugs, bird poo, hard water and such are left to dwell on clear coat. there are techniques and products that can be employed to greatly reduce the chance of any sort of damage.
the coating he applied is way more robust and harder than the factory clear coat. this means that the coating, not the original clear coat, will now face the environment and since it's SO much harder and more durable than the clear coat, it will be much more resistant to damage. and if it does happen to get slightly scratched or damaged somehow, at least it's the coating and not the factory clear coat.
think of it as a super thick, super hard WAX or sealant.
i have Opti-Coat Pro on two vehicles and i've had bird poo sit on a coated panel for several days, baking in the sun. this sort of exposure would surely permanently eat away at clear coat. when i finally attended to the bird bomb, it appeared as if it did etch the coating, but, within a few days, the staining completely disappeared and it was perfectly smooth again. the bird crap didn't even phase the coating.
Very impressed with the initial condition of the paint and found it only needed a 1 stage polish which was protected afterwards with Opti Coat Pro.
Arrival
Rubber and plastic trim all masked up
Measuring the paint
Before
After
Opti Coat Pro about it be applied
Double checking our work with a light that omits the same color as the sun
No swirls
And the finished product
Arrival (you should have seen both owners' faces lol)
Masking off the rubber trim after the wash and clay
Taking paint measurements
Before
After
50/50 shot
Opti Coat Pro
Application
And the finished pics
I hope you enjoyed the pics as much as I enjoyed working on my favorite generation M5!
Just did some work on a Mustang that hadn't been touched in a little over a year, also did the owners Bentley that also hadn't been touched in a year, before and after shots of the paint. Oh yeah no pro just wanted to share some paint correction I did recently
I must say this is one of the most beautifulest 991s we have done this year and we had a great time working on it and admiring all the little details put together on this 4 GTS.
Paint wasn't in bad shape so just a quick 1 stage polish and then protected with Opti Coat Pro.
Enjoy!
Arrival pic
Paint measurement and plastic trim masked off
Before
After
Lovely metallic flake shot
Opti Coat Pro
And the finished pics starting with reflections off the hood
Definitely looking forward to maintaining this one over the years!
The shine on this M3 was still great but the swirls in the sun was annoying the client and he wanted to get as much of the swirls out as possible. We ended up doing a 2 stage polish which brought the paint condition to about a 9 out of 10 minus the deeper scratches.
Hope you enjoy the pics as much as we enjoyed polishing this one!
Arrival
Paint measurements
Before
After
50/50 shot
We had tried to schedule an appointment prior to this one but due to rainy weather we had to reschedule and he mentioned that maybe he was considering postponing the detail until the springtime, which is understandable. Luckily
... he had a change of heart and we were able to schedule a date where the weather worked in our favour!So in to the shop it came!
As usual, the arrival pic
After cleaning the wheels, 2 Bucket Method wash, and clay bar, we masked the rubber trim
Next up was to take measurements of the paint with our special paint depth gauge which measures via ultrasound due to a few panels not being made of steel or aluminium. This gauge is not cheap at all and costed us $3000
These are the results of the 1st stage of polishing
Before
After(did I mention that solid black is a pain in the a**?!)
Headlights & Taillights were polished as well
Before
After
2nd stage of polishing was completed and then an alcohol wipe down to remove the polishing oils. Finally Opti Coat Primer applied to prepare for the Opti Coat Pro application
Tape removed and little details such as removing polish with a tooth pick from the edge of the stone guard was performed
And finally the star of the show, Opti Coat Pro
A shot in the sun to show no more swirls in the paint
All in all minus some deeper scratches which I suspect may have been from people leaning on the car for pics and the fact that it is solid black, I would say we got the paint condition to about an 8.5/9 out of 10.
Here are the results
I love reflection pics
The lens flare pointing at the car is pretty cool
And the last pic to finish the walk around
Hope you enjoyed the pics!!!
Not really much else to say, got the call Saturday evening and it was in the shop by Wednesday
Arrival
Cleaning the wheels
Masking off the rubber and plastic trim
The whole front end is carbon fibre so we had to bring out our ultrasound paint gauge to measure the paint
Underneath the hood
Ultrasound measurements
Magnetic measurements
And on to polishing the paint.
There was already close to 5000km on the odometer so the paint had some light swirls to polish out before applying Opti Coat Pro.
Before
After
Before
After
The taillights were polished as well
Before
After
After the 2nd stage of polishing was completed we applied Opti Coat Primer via machine to the paint
We unmasked the trim and took care of some finishing touches like cleaning up the polishing dust and cleaning polish from the edge of the stone guard with a tooth pick
And finally applied Opti Coat Pro
Overcast day so the gloss was not photographing the best it could be, but still happy with the finished pics!
And the icing on the cake.... an autograph under the hood from Wolfgang Porsche!!!
Hope you enjoyed the pics as much as we enjoyed working on the car!
Thanks!
Hope you enjoy the pics!
Arrival
Cleaning the wheels
2 Bucket car wash
Claybarring the paint with the Nanoskin mitt
And measuring the paint. This is one of the lower areas earlier mentioned
Before
After
50/50 shot
After the polishing was completed we cleaned out the left over polish out of the tighter areas with our trusty tooth pick
And finally Opti Gloss Coat is applied
Now for the finished pics
I tried to get a sun shot to show the flake but it had already set to far. This is the best I could do.
Hope you enjoyed the pics on this R33 Godzilla!
Not really much of a back story, got a call inquiring about Opti Coat Pro, client inquired with a few Audi Club members who vouched for our work, then in it came.
Arrival
Cleaning the wheels
Claybarring the paint with the Nanoskin Mitt
Measuring the paint
Before
After
After polishing and prep for Opti Coat Pro cleaned the windows
Opti Coat Pro about to be applied
And now the finished pics
And a sun shot to show no more swirls
and we set up a date to get it detailed so the owner could have a fresh start.
Paint wasn't to bad but still wanted to do a 2 stage polish so that it could be as good as possible.
Arrival
Claybarred the paint with a Nanoskin Mitt
Measuring the paint
And on to the polishing
Before
After
After the 2nd stage of polishing we unmasked the rubber and plastic trim
And cleaned polish residue out of the tight areas
Then finally applied Opti Gloss Coat
And now the finished the pics
And a signature from Chris Green from over at Pfaff, not to sure who the other signature is from.
Not much to mention about the car itself, the paint wasn't to bad and the 1 stage was enough to bring it up to a 8.5/9 out of 10.
On to the pics.
Arrival
Cleaning the wheels
Quick measurement of the paint
On to the polishing
Before
After
Metallic flake looking beautiful
Opti Gloss Coat about to be applied
And finally the finished pics
Always a pleasure to take care of this clients cars and I hope you guys enjoyed the pics!
Instagram - OrionDetailing.Co
Facebook - Orion Detailing Co.
I brought my TSX to you last January. I always had non stop compliments on the paint on a 12 year old car because of you!
I will have to bring the new whip by for opticoat as my first order of business.
Amazing work man!
-Patel
Brand new R8 Spyder which I believe at the time was 1 of 2 in Canada. Very long time client, probably 10 years now so everything was very straight forward. Got the email that this new Spyder was expected and that Opti Coat Pro + was wanted for protection as well as Opti Coat Fabric for the canvas top.
Anyways no more talk, here she is.
Arrival
Measuring the paint
I'm finding with the new Audis being delivered they are coming with some scratches specifically in certain areas and learned they don't have shipping plastics anymore but use a cover that is clipped on which I believe is the cause.
Before
After
Shot of us polishing
Preparing the top for Opti Fabric to protect the canvas top
Opti Coat Pro + about to be applied in 3 layers which is our thickest and shiniest coating
To the paint
Headlights
Taillights
Wheel faces
Doorjambs
Exhaust tips in and out
Glad to finally be posting again! Hope everyone is doing well!
Thanks,
Wes
(647)999-8499
Instagram - Orion Detailing Co
WeChat - Orion Detailing Co
