C63 AMG (W204) 2008 - 2015
Weistec Stage 3 build w/ replacing head bolts thread.
Old Mar 27, 2013 | 09:18 AM
Merc63's Avatar
C63 AMG
Rags, I'm just going off what Weistec told me. I'll know more once I remove the stock bolts.
weistec has built plenty of these engines now so aim sure they know what they are doing.
Coolant may get past the bottom threads, but the top is where the seal is, so I don't see it necessary to silicone the bottom.
Old Mar 27, 2013 | 09:26 AM
rags260z's Avatar
2011 C63, '78 LS1 280Z, '71 240Zt, '87 Grand National, '01 F150
It's great to see someone on here actually swinging wrenches!
Joe
Old Mar 27, 2013 | 10:31 PM
Merc63's Avatar
C63 AMG
Anyone ever remove the rad on one of these??
I cant get it past some lines to the other coolers... Not removing those lines and spilling oils and **** everywhere..
Rad slipped out of my latex gloves and landed on the tip of my finger.. Almost turned into the hulk it hurt so bad.
Might just leave it in the car after all... should have enough room to get my 90degree air drill on the crank end to drill for the new pulley.
Going back in to clean out the holes where the head bolts are with brake clean and my sucker.
I took a piece of metal as long as a head stud and just looked around at the back of the heads where the heat shield is.. Appears to be enough room to get the bolts out and studs in without disturbing the heat shield.
Old Mar 27, 2013 | 11:49 PM
Merc63's Avatar
C63 AMG
Well I thought the head bolts were situated in a galley or cylinder in the head... I was wrong.
The head of the bolt is open around the valve springs. Its still do able but going to be tedious. If we drop a washer or nut trying to put it onto the studs, it going to turn into a big headache.
Old Mar 30, 2013 | 04:58 PM
Merc63's Avatar
C63 AMG
Cams are out and studs going in.
Check out the rust on the stock head bolt. No wonder they are snapping off. The ****ty design plus corrosion.
Stud in:
Old Mar 30, 2013 | 05:19 PM
bhamg's Avatar
C63 AMG
Well seeing your head bolt has convinced me to replace mine this coming winter. No doubt about it.
Old Mar 30, 2013 | 05:40 PM
  #32
BerBer63's Avatar
2009 C63
Wow, send those pictures to MBUSA. thats horrible
Old Mar 30, 2013 | 05:57 PM
  #33
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What torque spec are you using for the bolts on the new studs?
Old Mar 30, 2013 | 06:07 PM
  #34
Merc63's Avatar
C63 AMG
The ARP studs, we are bottoming them out and backing it off a turn. Then torquing the nut to 110 ft lbs per Weistecs instructions.
The MAIN issue with these studs is they run right into the water jacket in the crank case. So you must clean the surface where the washer seals perfectly and seal it with silicone so coolant doesn't seep by and get into the head.
I am sure glad we switched to studs after pulling these stock bolts. All of them are rusted except one so far.
Old Mar 30, 2013 | 06:18 PM
  #35
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Thanks for your pictures. And a WTH award nomination to MB for sourcing faulty hardware.
Originally Posted by Merc63
Old Mar 30, 2013 | 07:27 PM
  #36
RossN's Avatar
2002 ML55, 2006 C6 Z06
What's going on with your tappet buckets? Is upgrading to M159 buckets part of your plan?
Old Mar 30, 2013 | 08:04 PM
  #37
Merc63's Avatar
C63 AMG
Not doing the tappets. They look good.
Passenger bank has the studs in. Bolting cams back in now and onto the next side.
We made marks to know where the cams go back into position.
Reading George's build thread was helpful. We pulled out the pink nail polish too.
Old Mar 30, 2013 | 08:12 PM
  #38
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Unbelievable work and excellent documentation.....wow you are going to be one happy camper once all is done and you are driving with confidence!
Old Mar 30, 2013 | 09:04 PM
  #39
Merc63's Avatar
C63 AMG
7 hours to pull cams, install studs one by one and re install cams.
Will be tackling the other bank maybe tomorrow.
Old Mar 31, 2013 | 06:19 AM
  #40
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Merc...the rust on the head bolt....all I can say is WTF? You maintained your coolant changes, right? motoman
Old Mar 31, 2013 | 11:09 AM
  #41
Merc63's Avatar
C63 AMG
Coolant changes are something like every 15 years or 150,000km I think.
This car is a 2010, with 60,000km. Expect older cars to be worse and get worse.
Metallurgy deficit I'd say.
Old Mar 31, 2013 | 11:21 AM
  #42
Merc63's Avatar
C63 AMG
ARP 625 head stud from Weistec:
Moly on end in the block, 500f silicone on threads in the head.
Studs are all in and torqued to 110ft lbs. cams are back in and lined up perfectly with our set marks.
Old Mar 31, 2013 | 11:27 AM
  #43
whoadude's Avatar
CLK63BS, 991 C2S, F86 X6M
Thanks for documenting this! Keep the pics coming!
Old Mar 31, 2013 | 11:37 AM
  #44
Merc63's Avatar
C63 AMG
I'm going to put the headers on today or tomr. Tuesday, we will do the studs on the driver side bank.
After the studs are done, we will start doing the blower install. Hopefully around that time, the ECU/tcu are back from tuning, we can finish up and fire her up.
Old Mar 31, 2013 | 02:59 PM
  #45
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Great thread, very informative
Old Apr 1, 2013 | 05:43 PM
  #46
GrnLantern's Avatar
SLS
+1
This thread is filled with awesomeness. In for updates as they come.
Old Apr 1, 2013 | 05:48 PM
  #47
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
+63, then report back
Old Apr 1, 2013 | 06:02 PM
  #48
BLACKONBLACKC63's Avatar
c63amg
What special tool did you used to put timing mark back to spec? and where can i order one? Thank you
Old Apr 1, 2013 | 07:46 PM
  #49
Merc63's Avatar
C63 AMG
You rotate the engine so that the 40degree mark on the crank pulley lines up with the mark on the block above the crank pulley.
You need one Mercedes cam adjuster locking tool and a 4mm bolt to lock both cams.
We made marks on the cams and referenced them with the head to know where the cam went back in. The teeth on the pulley are big enough that if you were off a tooth tour marks won't line up close.
Once marks are made, you have your merc tool locking the exhaust cam and the 4mm bolt locking the intake cam adjuster, you unbolt the cams one at a time. Slowly and equally removing the bolts as there is valve spring tension pushing on the cam.
You need the cam locking tool to put the cams back in other wise it's nearly impossible to press the valves down to get the cam bearing/holder brackets on without the cam flopping side to side and coming off your set marks.
It looks complicated but once you take the cams out you quickly realize how simple and easy it is. Main thing is marking the adjuster/cam in reference to the head so it goes back down exactly where it came out.
Old Apr 1, 2013 | 08:27 PM
  #50
c63amg
Can you please tell me the part# for that special tools? Thank you so much.
