Drag wheels and tire set up
2014 Audi RS7
Hey guys,
If you are interested I can get you a set of the ultralight weight set of drag skinnies and rears. I have a local shop custom make them for me. I've had a couple more sets made for drag racers. You will need a set of 30MM spacers for the front.
M&H 4.5 x 26"-17 Drag Front Runners.
Fronts wheels:
17 x 4" - solid aluminum one piece black anodized $886 each.
Rear wheels:
16 x 8" black anodized with the stainless screw package are $598 each.
They can be drilled and screwed if you want them done.
The fronts are 17 x 4" one piece and weight in at 11# and with the tire only weight 21#. They will poke out a little on the front to clear the brakes.
![Drag wheels and tire set up-frontskinnies_zpscc238b5d.jpg](https://mbworld.org/forums/attachments/c63-amg-w204/410043d1542335142t-drag-wheels-tire-set-up-frontskinnies_zpscc238b5d.jpg)
![Drag wheels and tire set up-48bb6d48.jpg](https://mbworld.org/forums/attachments/c63-amg-w204/410044d1542335142t-drag-wheels-tire-set-up-48bb6d48.jpg)
![Drag wheels and tire set up-4eb3f1e5.jpg](https://mbworld.org/forums/attachments/c63-amg-w204/410045d1542335142t-drag-wheels-tire-set-up-4eb3f1e5.jpg)
The rears can be 16 x 8" all the way up to whatever you want. I beleive the rears were around 14/15#each. I am double checking the weight.
![Drag wheels and tire set up-6b158548-7515-49c3-b253-f09b8df70507-46734-0000142fac171f17.jpg](https://mbworld.org/forums/attachments/c63-amg-w204/410046d1542335142t-drag-wheels-tire-set-up-6b158548-7515-49c3-b253-f09b8df70507-46734-0000142fac171f17.jpg)
![Drag wheels and tire set up-d6475cf9.jpg](https://mbworld.org/forums/attachments/c63-amg-w204/410047d1542335142t-drag-wheels-tire-set-up-d6475cf9.jpg)
PM me if you are interested.
Fronts wheels:
Rear wheels:
2014 Audi RS7
I was able to get a better price on the fronts. They are $886 each. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
They are made from a solid block of aluminum because they don't have a forging.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
If you want the absolute lightest set up this is it.![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
The believe stock front wheels/tires weigh approximately 56# or something like that and these are 21# tires and wheel, WOW!!
2014 Audi RS7
Every set is custom made to order. Let me know what you want and I will get it coming. It takes 2-3 weeks for production and anodizing. Let me know if I can help you with anything.
Thanks,
Keith
Thanks,
Keith
2014 Audi RS7
I had 15" on mine but I changed to the C350 rear brakes.
From what I have been told there are other 16" wheels that fit over the stock rear C63 brakes. That is why I was assuming these will be fine. I believe Dodger was running some 16" stock MB wheels.
Right now they only have the one design for our car.
Well I will keep you posted, honestly speaking I would rather pick up a set of cheap wheels in a 16"-17" since I really won't be using them that often.. any recommendations? I know ccw can make me wheels but they would cost about the same as the ones you are mentioning above.
I think I read somewhere that some guys where running TSW or something like that?
Could any one help with what kind of specs I would be looking for?
