Racing with new Weistec 3.0L setup.
Jrcart is making over 900rwhp on the CLK BS and a bit over 600rwhp with the C63 BS.
Jr's C BS, is running a different exhaust and I am not sure what other mods.
OP doesn't have an X pipe which Weistec has said is pretty influential to the output.
Former Vendor of MBWorld
Actually guys this car is at around 5500 ft elevation. Based on our testing the boost drops about 2-3 psi at this elevation. If you were to bring this car down to sea level it will make the same power or very similar to JRcarts. Our Stage 3 system will make close to 11 psi at sea level.
The CLK that is making more power because it is around 18psi, bigger intake inlets, much better exhaust, aggressive tuning, etc. however, even our built motor packages retain the factory compression ratio. Hope this helps. Thanks guys!
Weistec Engineering
Weistec Engineering
JR's car is similarly modded except for the fact that his Trans is still stock
#33
2009 c 63 amg eurocharged
