C63 AMG (W204) 2008 - 2015
Lowering C63 with coilovers questions
Old Apr 12, 2013 | 06:23 PM
natman316's Avatar
2012 C63 2015 C300 sport
I am considering getting KW V3, will I need a camber kit to correct the camber when lowered?
also do KW v3 come with adjustable top mounts where I can change the caster/camber settings?
I want a drop, but I also dont want to ruin the handling as I still track my car, so I wanted to check if there is anything else I should install when I install coilovers!
Old Apr 12, 2013 | 06:47 PM
Footbrawler80's Avatar
Veteran: Air Force
2009 Mercedes Benz C63 AMG PP (Weistec S3 Supercharged)
You should not need a camber kit
Old Apr 12, 2013 | 08:52 PM
natman316's Avatar
do they have a caster plate on top?
also can you choose spring rates etc?
Old Apr 13, 2013 | 02:07 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
You will need rear adjustable upper control arms to correct for too much camber after you drop it.
Old Apr 13, 2013 | 02:12 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Interesting thread. I'm thinking of lowering the car as well.
By the way how much for this kit and install?
Old May 22, 2013 | 11:47 PM
natman316's Avatar
so bumping this thread real quick so i dont make another coilover thread.
I ordered KW v3 from vivid the other day...process was a breeze and Arsha is great to work with!
Has anyone done a DIY install? How hard is it. I've done coilovers on Hondas and they werent too bad, but I'm sure this is more complicated.
also I got quoted for a shop install of around 350, good price?
lastly, how do I determine how much lowering I want? (i havent got the kit yet, will it be in the instruction?)
thank you all
Old May 22, 2013 | 11:51 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
That price sounds about right.
Old May 22, 2013 | 11:54 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Can't wait to see ur car slammed Nate!! Just make sure they don't send u OEM shocks/springs .. J/k lol
Old May 23, 2013 | 05:36 AM
wahlsten's Avatar
C 63 AMG
I mounted H&R Coilovers last week... it take me about 8 hour...
I have "klonk" sound in the front end when i steering full in low speed...
any one knows what it could be?
Old May 23, 2013 | 09:49 AM
natman316's Avatar
Lol Meng you are the one that finally pressured me into lowering hahaha.
Old May 23, 2013 | 09:55 AM
Roswell's Avatar
.. did I mentionned you also need sideskirts/rear skirts to complete the drop? *drool*
Old May 23, 2013 | 09:59 AM
natman316's Avatar
Nooo! After the drop im getting a new diffuser that wont fall off and a front lip and thats it for exterior stuff hahaha
Old May 23, 2013 | 10:03 AM
Roswell's Avatar
lol... make sure the lip doesnt fall off too. Do I smell Vorsteiner diffuser?
P.S The sideskirts look so classy on black cars.
Old May 23, 2013 | 12:41 PM
LFM_Vancouver's Avatar
C63s now in the garage. Sold-GLA45 AMG Edition 1, Sold-2010 Mercedes C63
thank you all
When I did my V3's I got many quotes. Scan Automotive in North Van quoted me $1800 for install only!!!!! Ended up paying $350 at another shop. After watching them do the instal I would just pay to have it done. If you don't have access to a lift the job would be very frustrating. Make sure they double check the ride height before installing the coil overs. If your a little out it's a real pain to adjust the rear after the car is back together.
Old May 23, 2013 | 12:47 PM
From what I've heard when I had my ride height adjusted, any tweak to the suspension for coilovers require the entire thing to be disassembled to adjust the height. Then you have to put everything back and let it settle before you get a true idea of the ride height. If you don't have the expertise or equipment, I would definitely pay to have it done. And the KW V3 is probably more complex than my suspension.
Old May 23, 2013 | 01:05 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
Set the fronts first as these are a major PIA to adjust. The backs are easy since they are not true coilovers. There is just an adjustment collar on top of the spring in place of the rubber pad. Either use a spring compressor to get to the collar or drop the lower control arm. Use a jack under as even at full drop there is spring tension. I had ACG in SD do it. They've done so many times they get the height correct on the first try.
Old May 23, 2013 | 05:59 PM
natman316's Avatar
hmm thanks for the advice guys, i may end up having the shop do it then...the only bad thing is seems like shops around me cant accommodate for 2 weeks! And i recieve the coils tomorrow....I'll look around some more. so just to clarify, once they are mounted, the front height cannot be changed but the rears can?
Old May 23, 2013 | 06:05 PM
What shop is busy for 2 weeks? There isn't another shop you can go to?
