Front camber
Huracan STO
Front camber
I installed my KW v3 (no wheel gap at all around the whole car.) the rears are fine because with my offset, the wheel/tire just clears the quarter. For the front it has a crazy amount of camber. Are most people just leaving it like this or what? I found this part (camber bolt) # by searching 000-333-09-71 they say it will add .5 of positive camber to the fronts. Just want to see how everyone else is taking car of this issue or just leaving it as is. Thanks
Tom
Tom
My car is dropped on H&R Sports and has a slight gap. Over time i became annoyed on the negative camber and how it made the car look. I installed the bolts and it helped a little. Then i took my car to an alignment shopped that "slotted"(not sure of the correct terminology) my front to correct the negative camber and made the tire more flush. Cost me 50 per side plus the alighment.
Now i need the rears done. not sure if bolts can correct our negative camber as my inner wall of my tires are getting eatin.
