People with Tail Light Issues!
I'll be ringing MB customer service tomorrow, I'll also email and ask them why they haven't had a recall on this problem, as I have said, this is the second time I've had to replace them.
Been wanting a Benz for years, now that I've got one I don't know why I bothered, should of stuck with my Hyundai less money less trouble.
This year I had to replace
Cruise control
Water pump
Thermostat housing
Charge air hose
All three Engine mounts
And now have the tail lights fixed once again.
I have been lucky had most of it done under MB goodwill policy
Cruise control
Water pump
Thermostat housing
Charge air hose
Gee Whiz, Doesn't say much about the engineers that designed the Globe carrier & the wire harness.
Anyway, long story short, after about hour hanging around they said there's been and upgrade to the harness so with a little luck the parts will be here tomorrow and fitted.
Doing both sides and they mentioned the car is out of warranty, again I "politely" told them I don't care it's a manufactures problem I won't be paying for it, and quite happy to take it further.
http://www.allworldauto.com/inv/NHTS...ion_98047.html
I'm assuming the C300 has the same tail lights & harness configuration as my C220CDI 2009 W204 .
Can you send me the link where I complain to NHTSA even though I live in Australia.
https://www-odi.nhtsa.dot.gov/ivoq/
It won't accept my Vin No
I would have thought there would have been many more complaints.
I also had it confirmed that there will be no cost to me.
So lets hope i'll have no more problems, I'm not holding my breath though.
Those 21 complaints are most likely from folks who had to have the lights replaced out of warranty at a significant cost to themselves.
For each complaint, MB has to respond (a complaint does not automatically mean NHTSA will investigate further though). after a few complaints, in this case, 21, NHTSA will open an investigation, and depending on the outcome, may ask MB to do a voluntary recall. They could also force a recall, since the tail light issue can also be considered a fire hazard.
However, NHTSA being a federal entity, they tend to take ages are and slow, so it might be a while.
I can certainly see a lot wouldn't or can't be bothered to complain sad really, because if they did it make it so much easier and less hassle for everyone.
So far I've had no problem getting things done well out of warranty, I'm sure the reason is because they bloody well know there's been a lot of problems with the same parts that I've had replaced.
By the way I had all the engine mounts (3) replace for no charge also a water pump/ cruise control no charge and air charge hose that they quoted me $821.00 reduce to $280.00 thermostat housing From $264.00 to $78.00.
So I have been quite lucky however in saying that I didn't really expect these parts to fail in a 2009 model C Class.
The car has done 125,000Klm when all were replace so hopefully I won't have any more trouble for a while.
i'm wondering if there is actually a fix for this... or will they just replace with the same part and it will likely happen again.
I must say the local dealership is fantastic, they do everything they can to help, I more than likely wouldn't have the Benz if wasn't for them.
