C63 AMG (W204) 2008 - 2015
Wheel fitment help
Old Oct 12, 2013 | 06:18 PM
verteu's Avatar
W212 E63
Wheel fitment help
Will this wheel spec fit on a C63?
Front: 20 x 8.5 et33
Rear: 20 x 9.5 et37
Old Oct 12, 2013 | 07:22 PM
Ingenieur's Avatar
C63 AMG
Rear: 20 x 9.5 et37
probably not
Front outside +18 mm, inside -6 mm
Rear outside +24 mm, inside -12 mm
Old Oct 12, 2013 | 07:33 PM
charliekay's Avatar
C63 AMG
I'm not an expert but I am pretty sure your inside clearance will be fine. You might be running pretty close to the fender but they may work with stretched rubber.
There a lot of wheel gurus here so they will chime in soon.
Old Oct 12, 2013 | 09:18 PM
noodleman's Avatar
2014 E63S Wagon
not without stretched tires and crazy camber.
Old Oct 13, 2013 | 01:03 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
^ this.. In other words, no good!
Our cars need +50mm or higher offset in the rear.
Old Oct 13, 2013 | 01:52 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
^ Listen to the man!
Plus why do you want 20" anyways? Too big
Old Oct 13, 2013 | 10:38 PM
verteu's Avatar
W212 E63
Thanks for the info guys!
