C63 AMG (W204) 2008 - 2015
Question about 2010 pp pkg !?!?!?
Old Nov 3, 2013 | 06:37 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
I did some research but still not 100% sure... can someone help me ?
my 2010 c63 amg pp . it has 2 piece front disc / cf trim / LSD / alcantra steering wheel
1.has stiff stock susp. is it slightly lower than reg c63s ?
2. will I rub with 12mm spacers in the rear with stock 18" wheels wrapped with 275s?
2. does it have extra 30hp ? ( I can post vin if needed)
thank you so much
Old Nov 3, 2013 | 06:45 PM
Mort's Avatar
1. I don't think the P30 is any lower than a regular C 63 but don't know for sure.
2. Try the spacers and see if it rubs. Since you are not lowered you might be fine.
2. (LOL). The P30 did not get the extra 30 hp but the speed limiter is raised to 174mph.
Old Nov 3, 2013 | 06:47 PM
dchl21's Avatar
cool thank you!!
no so worried about hp anyway.. a tune would prob get more. ill do that once extended warranty is up.
Old Nov 3, 2013 | 07:27 PM
dchl21's Avatar
any one knows if its lower ?
Old Nov 4, 2013 | 12:12 AM
dubzAMG's Avatar
2010 C63 AMG FBO, 2014 E63 AMG S
2010 has the p31 which doesn't have the stiffer suspension, and yes you have the extra 30 horsepower
Old Nov 4, 2013 | 12:39 AM
dchl21's Avatar
..... but I do have the stiffer sus.... its very stiff
Old Nov 4, 2013 | 01:46 AM
bmoney12's Avatar
2019 Audi TT RS, 2020 BMW X3M Competition
Could be P30 or P31 for 2010.
http://www.benzblogger.com/2009/11/2...laces-p30.html
Old Nov 4, 2013 | 04:32 PM
Mort's Avatar
Think dchl21 has the P30 or else he would have the red brake calipers.
Old Nov 4, 2013 | 05:34 PM
rnorthen's Avatar
2010 C63
The p30 option (on early my2010) does have a lower and stiffer performance suspension. It's the best c63 you can own as the extra hp of the p31 is easy, cheap and reversible for servicing if necessary. After driving a p30, other c63 feel a bit floaty and loose...
Old Nov 4, 2013 | 06:43 PM
dchl21's Avatar
yes ive p30 ...
thanks a lot guys .. I guess I got it all except the hp.
Old Nov 4, 2013 | 07:01 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
U will rub with 12mm & 275/30/18.. Cuz ur oem wheels will be 18x9 +44, and 275/30 is very aggressive.
But as Mort said, u got nothing to lose than to try it since u r at stock height, it won't rub unless u have passengers or go over bumps at high speed.
Old Nov 4, 2013 | 08:26 PM
dubzAMG's Avatar
Originally Posted by bmoney12
according to your link, 2010's have p31, which doesn't have the stiffer suspension like the p30??
Old Nov 4, 2013 | 08:58 PM
dchl21's Avatar
ya ... p31 = red caliper / +30hp
p30 = LSD / stiffer sus
Old Nov 4, 2013 | 09:04 PM
avery.whss's Avatar
S550 on order
easiest way to tell is if your intake manifold is a dark grey its a P31...if its a white/grey then its a P30...I'd rather a P30...you can get the extra HP from a simple tune...LSD and the suspension helps alot
Old Nov 5, 2013 | 08:20 AM
Mort's Avatar
Typo, the OEM rear wheels are 18x9 +54
A lot of guys run 10mm spacers on the rear with OEM wheels so trying the 12 mm and seeing how you make out shouldn't be too big a deal.
Yes, the darker grey intake manifold should be proof positive of a P31 engine build.
Old Nov 5, 2013 | 09:23 AM
Roswell's Avatar
Oups, not a typo just a miscalculation lol
18x9 +54 - +12mm spacers = +42mm offset, not +44mm.
I'm running 10 mm spacers right now (+44mm) on my oem wheels, and I'm on 255/30 & it's tight fit.
My guess is 12mm (2mm further out) & 275/35/18 (20mm wider tires) will not clear the fenders. But stock height & stiffer suspension might minimize rubbing, but I still think it will rub.
Old Nov 5, 2013 | 09:32 AM
bmoney12's Avatar
It states starting with December production so P30 was offered early on in 2010 model year which would be what the OP has.
