C63 AMG (W204) 2008 - 2015
Launching at strip with MCT??
Old Nov 8, 2013 | 06:08 PM
skaarlaj's Avatar
ford svt's, and C63!!!
I'll start off by saying I really enjoy driving our 2012 C63, it's set-up very smart and nice on the interior, runs/sounds/drives awesomely, butt.. I also like the drag-strip, but simply cannot get a good launch with the MCT.
I think a regular torque/stall converter would get the beast off the line cleaner/smoother. It's just a very fine line between spinning and bogging, with the clutch system, and with all the stuff going on at the tree, I'm reluctant to use "race start", maybe that's my issue, but let's just say I've never came close to a sub 2 second 60' on Nitto drag radials.
Also know that the track I like to go to is here in Wyoming and the elevation is above 7000', so there's a serious power deficit, but it still pulls pretty hard and should 60' below 2 seconds, at least occasionally, any ideas, or tricks to get these MCT equipped C63's to launch a little better?
Currently, I just hit the gas, and soon-after, release the brake, and it sort of "pops the clutch" sort of speak. If you stand on the gas, and brake, it only allows the revs to barely break 1000rpm's and it just plain boggs off the line, unlike a torque converter equipped auto. I should try manually shifting it, but don't want to give up time by accidentally short-shifting, or hitting the rev-limiter.
Old Nov 8, 2013 | 08:04 PM
Merc63's Avatar
C63 AMG
Id say just hammer it off the line, does the rpm jump up and it grabs??
if you stall it, it might cut timing.
at 7000' ft don't expect nothing crazy. Its going to be a slug.
Use M mode, it shifts faster.
Did u get headers?? Once you get those on, it will come alive more.. The stock system is so restrictive.
A race gas tune is good for .1-.2
Remove passanger seat and everything in the trunk.
Old Nov 8, 2013 | 11:23 PM
TTA850's Avatar
2015 E63S AMG & 2013 GLK350
On stock tires the best I've gotten is a 1.87 though 1.9x is very routine. Finding that fine line and rolling on the throttle just right is tricky. After the headers best I saw on stock tires was a 1.94 traction was just not there but on M/T drag radials I've been 1.78 using race start. Keep in mind though, I'm at sea level.
Old Nov 9, 2013 | 03:37 PM
skaarlaj's Avatar
It actually mph's good, feels plenty powerful, just not strong out of the gate? I'll have to try race start.
Old Nov 10, 2013 | 06:41 PM
Ezec63's Avatar
C63 Coupe
What technique did you use for the 1.87 on streets? Did you preload any revs before launching and just feather the throttle out?
How about on MT's? Just smash on the way out?
Old Nov 11, 2013 | 10:43 AM
TTA850's Avatar
On stock tires my best short times came from leaving at idle and rolling on the throttle, the tricky part was figuring out how fast or slow to roll on it (and actually getting it right). Too slow and it would barely short under 2 seconds, too fast and the clutch would lock quickly and blow the tires away.
On the M/T's I found race start worked very well with consistsnt 1.78-1.80 shorts, smashing the throttle with the ESC off resulted in a broken driveshaft so I wouldn't reccomend it lol
Old Nov 11, 2013 | 11:23 AM
PTW's Avatar
PTW
C63 Coupe
What tyre pressues were you running for stock mate?
Old Nov 11, 2013 | 11:34 AM
mdgrwl's Avatar
C63 AMG
Best way to launch at the track is this:
- 25psi on Stock Conti Tires
- Good solid burnout and roll out of it
- Traction completely off
- Transmission is S+
- Brake hold at 1500rpm
- At 3rd amber, let off the brake and "roll onto" the throttle gradually. << This is the hardest part to learn. Too much throttle and you'll spin. Too little throttle and you'll get 2.0+ 60ft. It takes some time but you'll be able to "feel" when you have a good solid launch.
My best 60ft was 1.93 so far... but I can see getting 1.8x with more seat time. 1.93 was my first time at the track... resulted in a 12.25 @ 115mph
Old Nov 17, 2013 | 09:43 PM
SoFlaC63's Avatar
96 C220, 85 300D, 2012 C63 AMG
I have the 2012 C63, found the best way to launch my car is with the launch control. Times are very consistent. Get it setup and let off the brake. The car leaves perfectly every time. No spinning or wheel hop. Wont launch it any other way.
---Side note. I had a pass that had horrible wheel hop. Next day i noticed a POP when put in drive and given gas. Did this every time i stopped and drove off. Dealer diagnosed it as a blown diff.
Old Nov 17, 2013 | 09:52 PM
SoFlaC63's Avatar
Old Nov 17, 2013 | 10:46 PM
zibby43's Avatar
'20 GLC300 SUV
Yikes. Good luck with getting that replaced man.
I knew I wasn't crazy when I was experiencing wheel hop on my stock C63. I found that warming up the tires extensively eliminated it.
With all the mods that you have, it might be inevitable under certain conditions.
Old Nov 18, 2013 | 10:45 AM
mdgrwl's Avatar
C63 AMG
What do your time slips look like? 60ft especially?
