Head Bolt Affected VIN - 2010 & older, & early 2011s
#526
The issue is in fact worldwide for all M156 engines in all car models. Given that yours is a 2010, but from the US, you're probably not affected. This is because unlike rest-of-world US car model years are not tied to the calendar. If you want to be sure if you're clear, respond back with your VIN and I will run it. Also, to your comment about the Mechanics, I've attached the Technical Service Bulletin that covers the issue. Also the TSB was pulled down off of MB servers. Wonder why? :-)
Thanks, I'm not saying that this issue doesn't exist but it's always nice to make sure
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
I have pulled out the data card for my car
My engine: 156985 60 049858
The car got 44xxx miles on it, haven't experienced any low coolant level yet.
I haven seen some guys change a lot of stuff not only the head bolts, cams, gasket etc. MB changed the cams right? Do you know the reason for that?
#528
I liked your attachment
#529
2011 C63 AMG
2011 here, if you could please let me know if affected and a data card would be awesome thanks!
WDDGF7HB3BF646313
WDDGF7HB3BF646313
#530
WDDGF7HB3BF646313
WDDGF7HB3BF646313
Regards,
Joe
#532
I have been very interested in a 09 at carmax may i have the data card on this WDDGF77XX9F263136 and please let me know if this is one is affected
thanks
thanks
#533
thanks
thanks
Regards,
Joe
#535
2010 c63 head bolt affects engine
i have 2010 c63 with vin WDDGF7HB8AF451838 ... Is my car is in the bad head bolt affects range
#537
#538
Regards,
Joe
#539
Can you please check this vin 2010 e63 I am thinking about purchasing it
WDDHF7HB3AA163064
WDDHF7HB3AA163064
#540
WDDHF7HB3AA163064
WDDHF7HB3AA163064
Regards,
Joe
#544
Looking at another 2010 E63 VIN: WDDHF7HB4AA141400
Thanks a lot for the vin check Valve! I hope this ones good so I can finally buy something!
#545
The title of the thread states - "all 2010 and older, and some early 2011s".
So all 2010s are affected. If you don't want a car that's affected, you need to look at 2011s (and I will look them up if you find them) and 2012 or newer.
Hopefully this is clear.
Regards,
Joe
#547
Regards,
Joe
#548
Head Bolts
I am new to forum. About to purchase a 2011 C63 AMG. Need to know if the motor has revised bolts. VIN# WDDGF7HB5BF648113. Also would like the data card too.
Thank you, Gary
Thank you, Gary
Steiner (05-25-2016)
#549
Thank you, Gary
Thank you, Gary
Regards,
Joe
