Head Bolt Affected VIN - 2010 & older, & early 2011s
#1326
Hi, I joined this forum because I'm in the market for a 2009 SL63. I called an MB dealer and gave them the VIN's and they told me that there are no open or previous recalls on these two cars I'm looking at. I was under the impression that all 2009 SL63's had the M156 engine and is in range of the problem. The two VIN's I'm looking at are:
WDBSK70FX9F154708
WDBSK70F49F146992
Any info/insight is appreciated. Thanks
WDBSK70FX9F154708
WDBSK70F49F146992
#1327
There are no recalls Mercedes never accepted responsibility to fix them all and chose to fix only the ones that had failures under warranty and or at their discretion. Both of those cars will have the old failure or own head bolts unless they have already been switched out
#1328
WDBSK70FX9F154708
WDBSK70F49F146992
WDBSK70FX9F154708
WDBSK70F49F146992
#1329
2011 c63 WDDGF7HB4BF648989
please check if its affected thanks
#1330
2009 cls63 headbolts issue check by vin
Hello.
ive been hearing about Mercedes m156 engine headbolts issue... any way you can check on this Vin for me? Vin: WDDDJ77X59A151861
its 2009 cls63
thanks
its 2009 cls63
thanks
#1331
Hello.
its 2009 cls63
thanks
its 2009 cls63
thanks
#1332
#1334
2008 CLK 63 Convertible
I'd appreciate your help. 2008 CLK63. WDB2094771T099662
engine: 156982 60 029703 156.982 M156 E63 V8 Gasoline
#1342
#1343
Any chance to look up my VIN
Hello Joe,
I have owned a 2009 C63 for the past three years and came across this thread. I do not have any issues with my car but would really like to know if my VIN is affected with the bad engine head bolts.
Much appreciated if you could help me out.
VIN: WDDGF77X49F236580
many Thanks in advance.
#1345
Received 2,831 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/1261x822/69c77785_5df6_44c3_a271_194066734027_c22ce50876c9af8be8d398466871079e48e4b697.jpeg)
#1346
#1348
Thanks. That’s what I thought. Just needed confirmation.
adding to my previous comment: my contact at Mercedes Benz in Germany said that all vehicles up to 068xxx are affected and since my vin is 236xxx I should not worry- well until I came across this thread tonight!
#1350
Possible to get Datacard for WDDGF77X49F236580. Thanks!
