C63 AMG (W204) 2008 - 2015
Wheel offset question
Old Dec 26, 2013 | 02:52 PM
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
Hey guys, would these wheels fit my C63 sedan? Here is the information... 19x8.5 5x112 and the offsets are et44 all around. Thanks in advance!
Old Dec 26, 2013 | 05:20 PM
Ingenieur's Avatar
C63 AMG
oem
front is 45 8" wide
rear is 54 9" wide
front
basically a 1 mm spacer with 6 mm more outside (and inside) wheel
total +7 mm outside and + 5 mm inside
people are running 12 mm spacers without issues so should be fine
but tire size must be considered
rear
basically a 10 mm spacer and with -6 mm less outside (and inside) wheel
total +4 mm outside and -16 mm inside
will fit
again, tire size need factored in
Old Dec 26, 2013 | 07:26 PM
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
All my research (look for posts by Roswell ) says they will fit with the right size tyre.
The question is why would you? The C63 is struggling for grip to start with and you are going to go down in size on the rear. The rest of us are all trying to squeeze more width under the rear.
I have OZ Ultraleggeras in 18 x 8.5 on an A3 and they are a first class wheel but no way would I put them on the C63 as they are simply too small.
Old Dec 26, 2013 | 07:52 PM
CarHopper's Avatar
E63S | X5
You'll be happier with a 10 in the rears.
Old Dec 27, 2013 | 12:37 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I agree with all of above, they will fit but the rear will be too narrow.
Look for a staggered rear set of 19x9.5 or 19x10 +50 & up.
Old Dec 27, 2013 | 11:13 AM
adv4nced53's Avatar
2010 C63 AMG
Those will look terrible on your car. Read recommendations above.
