KW Rebound Adjustment in Rear?
So i decided to drill though so i could get some adjustment ability.
squared off and centered by using the bolts on each side
used a heart bur to start the seat for the hole and finished through with a ball bur.
clean hole on drivers side
another one on the passenger side same method.
This is a solution for people with KW v3 to adjust the rebound in the rear without having to undo the suspension.
You don't need it since you have DDC. Everything can be set remotely.
