Anyone else 3rd to 4th gear slip before engagement?
So first picture is the transmission all torn apart.
second picture shows the k1 clutch packs. They are only available as whole assembly.
third picture is the old k1's up close and burned up, they should look like a nice shiny machined surface with minor scapes or wear marks
fourth picture is the b1 clutch, it sits directly behind the bell housing of the transmission
fifth picture is the b1 clutches, nothing like the k1's but have some burn marks
sixth picture is the b3 going on top of b1, k1 goes inside b1.
first picture b3 is installed not the position of that hole, i put the little feeder tube that goes from the valve body into it to show you why this is important.
second b1 and b3 installed with k1 sitting in the middle
third is the k2 clutch pack with front planetaries
fourth is how k2 sits installed on top of b1 and b3 etc....
fifth this is what brand new clutches look like before soaked in trans fluid, this is the k3 clutch also only available as a full assembly
sixth k3 and its friend part.
k3 installed in its friend
k3 and friend installed in rear planetary
and k3 and planetaries stacked ontop of everything
All the remaining parts like br and b3 are in the back of the transmission casing, i inspected them and they were all in good shape. bottom line is 540rwtq w/o valve body upgrade from weistec and lots of "abuse" or as id call driving a c63 properly equals new b1, k1,k2 and k3s. keep in mind my car came with the 700nm transmission, I believe most of the mct's came with 1000nm version
Also, what special tools did you use. Also.. some of us DIYers are a little more capable than others (not that I do not believe others are capable). Anyone willing to take on a transmission knows the risks, so you do not have to protect us
That said, is the manual you used the same one posted in the tranny fluid change thread somewhere? about 200 page document with a complete breakdown of the tranny. Not really a paint by numbers, but easy enough to assemble.
special tools are minimal just to replace clutches. basic torx set, torque wrench, snap ring plier set, some flat blade screw drivers, picks, depth micrometer, straight edge, and you'll need a big socket for the nut that holds the tail shaft in, its a special tool - its a big 12point deep socket that hollowed out to allow the shaft to go in deep. If you plan on going all out and replacing piston seals and stuff you'll need alot of special tools. All my gears shifted properly so no piston issues, just slippage under full load, not enough grip to hold all the torque. I used wis and prior schooling for instruction.
did it at my work, which is a shop
Do you have a cost rundown of the parts list?
here's a list of what clutches are used for each gear. typically the one that changes when engaging that gear is the problem. There is also the possibility of a solenoid getting clogged up or valve body issue too.
I know theres been a few posts on this, but here is another incase ya'll missed out. This is the difference in the torque converter trans cooler and the mct. The one on the top is the power steering cooler, the middle is the transcooler for tq converter - which is about 2"-3" thick, the bottom is the much much larger - but only about 1" thick mct transmission cooler. They both have built in bypass thermostat which is nice. I dont really think i ever had issues with too much heat, but being in the south, daily driving, lots of extra power and the wife loves to hot lap the car when at the strip it cant hurt.
If you just wanted to make it directly fit the newer bigger one, you'd need a new radiator, condenser, mounting frame and some lines than what the older torque converter cars came with.
Last edited by roadtalontsi; Jul 15, 2014 at 11:03 PM. Reason: picture automatically turned 90* renamed locations
Car is FIXED!
-First thing they tried is swapping K2 and K3 solenoids. Did not fix it.
- Pulled tranny and sent to toronto. Replaced k1 clutch packs, rebuilt the torque converter. Couple of other things replaced also, dont have the full list of what happened there.
-Re-installed tranny. Problem still happening.
- Pulled tranny oil pan and replaced valve body. Put everything together and did adaptation procedure.
Everything good
Covered by warranty.Car shifting like new.
