Quick Advice, Need Help on Purchasing C63 507!!
Well it's no 'issue' that I know off per se, but if it was all replaced and fixed, why would you really worry? Perhaps there was a theft attempt or something, who knows. You can always ask the seller for details.
Hello all, new member here. Just needed some advice. I'm close to finishing a deal on a used 507 C63 with about 4k miles on it and car is in another state but it looks clean overall and CarFax looks clean except for one thing I noticed. Obviously its hard to say without me actually personally seeing it, but I cant do a trip currently.
Well anyways before it was offered for sale, it states on the CarFax that the Steering Column repaired, Steering Lock Replaced, and Ignition Switch Replaced. Is this a common or well known issue, or is it something I should be worried about? Any advice, comments, or helpful info would be greatly appreciated!
Is it the car in Buena Park, CA?
Jag F-Type V8
Steering column repair isn't all that uncommon. The motors for moving the column in and out often (somewhat) fail. Regarding the ignition, no idea; but, maybe the owner was having keyless go problems?
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
You give car thieves way too much credit. Sounds like an attempted "theft of opportunity" by some junkie. A professional car thief would know about the system, sure, but most car thieves are amateurs at best.
Yes, a steering column repair isn't uncommon, but "Steering Column repaired, Steering Lock Replaced, and Ignition Switch Replaced" together seem to point at only one thing.
