Went to the track now car pulls to the left?
07 E63 + 07 CLK63CAB
One must also realize that most likely you do not drive around with three people and three bags of luggage in the trunk unless you are looking for traction aids, .
Diabolis the strange reading on your gas door shows 44 in front and 42 in rear with specified loading, but full load seems normal. I guess the 19 inch lower profile needs less air pressure. Or two in the front and 1 in back with three 24's in the trunk.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Er - I suspect you mean the 19s need more pressure (they do in order to maintain the load rating as the sidewall is smaller), not less. I run 45F/45R on PSS 19s. Even tire wear throughout.
Realized that you have a coupe, that is why the rear pressure is less on the gas door. Less overhang on the rear axle as compared to a sedan. 44 front 42 rear
The car must hit hard when driving over so so pavement, reduced pressure would give you better ride and still uniform wear. 38 front/rear give it a try. IMO
#32
It would be nice to know why the 18" sedan pressures were changed from 39/39 to 41/41 and from 41/45 to 44/46. As far as I know the suspension is the same. Different OEM tires? Or would the new specs be recommended for the older cars now?
Maybe a tech can shed light.
#33
The standard LCI sedans now come with ContiSportContact 5P tires (at least that's one option).
#34
What kind of suspension changes were included? I have the Contis and like them. So the higher pressure could be for them?
#35
#36
The changes included: a redesigned front axle; a reinforced rear axle and widening of the front track; stiffer elastokinematics and revised geometry with more negative camber; and a larger rear stabilizer bar
They also revised the spring and damper rates.
#37
Don't want to hijack this discussion - we'll pick up the spacer question in a new thread:
https://mbworld.org/forums/c63-amg-w...ml#post6055137
