CHECK ENGINE LIGHT PROBLEM
You are emotionally involved with me which creeps me out
You seek affection on the internet? Lol you need to be 'liked '?
Are you going tp melt down like the sob in vista if you are not 'liked' or 'popular'? You are a sad little boy
The piston to cylinder clearance is ~0.002" cold, less hot
You think that is 'loose' and can 'wiggle'?
I am typing , not speaking, so lips dont move Einstein
You mouth breathing, lips move when reading mental midget
I bet it's a lean code which would state an intake leak. Easy to find and fix. Was the code ever posted by the OP?
Wonder if he did an air filter replacement or some intake track work recently?
But the code should tell you so maybe is not purge valve...
Sorry, thinking out loud here...
