C63 AMG (W204) 2008 - 2015
Eurocharged V5 Tune
Old Jun 5, 2014 | 07:33 PM
Exhibit13's Avatar
2010 c63 (p31) w/LSD
Is there a noise or anything on the display that shows that the reset was done correctly?
Originally Posted by nkc
Do this
1. Turn the igniiton key to the "on" position which is just before you crank the engine to start.
2. Press the accelerator to the floor and hold for 5 seconds.
3. Then turn the key to the off position but do not remove the key, then release the accelerator.
4. Wait at least 5 minutes, the ECU is then reset.
The ECU rest procedure only erases the adaptive transmission and throttle settings. It does not erase any of the fuel, timing or other programming.
Old Jun 5, 2014 | 09:29 PM
shades's Avatar
09 C63, 11 Cayenne S
No, you will definitely feel the difference because it's in learning mode. If you drive it slow, it will learn that....if you drive it fast and hard it will learn that. what I usually do after a reset is to make sure you have some time do drive it hard. Don't worry though, you can do this process over and over.
Old Jun 5, 2014 | 10:16 PM
08C63's Avatar
2008 C63
Originally Posted by zcct04
What's the process with keyless go? Pull the start button and use your key as above, or is there a little easier way?
The starter button just pops off and there is a key slot? Didn't know that.
Old Jun 5, 2014 | 10:24 PM
Exhibit13's Avatar
So you have to then after leave the key in the ignition for 5 mins or you can then lock and walk away from the car?
Old Jun 6, 2014 | 12:56 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
i believe you just have to not open the doors for the 5 mins. that's what i was told for my old w202 anyway...
Old Jun 6, 2014 | 01:23 AM
Exhibit13's Avatar
Ok so you do have to sit in the car for the 5 mins, will have to try this tomorrow!
Old Jun 6, 2014 | 01:24 AM
  #32
or climb out the window, dukes of hazzard style.
Old Jun 6, 2014 | 03:07 AM
  #33
ML63 AMG's Avatar
CL63 AMG
I told you they were amazing! Lol
Old Jun 6, 2014 | 03:13 AM
  #34
nkc's Avatar
nkc
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
Originally Posted by mr747
^^^^ pull the start button and use your key
+ 1
Old Jun 6, 2014 | 03:14 AM
  #35
C63DaKine's Avatar
W205 C63s AMG (Current) // W204 C63 AMG (SOLD) // E55 AMG (SOLD)
lol
