C63 AMG (W204) 2008 - 2015
Tire pressure adjustment for + sizes
Old 07-30-2014, 06:12 PM
  #51
Ingenieur's Avatar
C63 AMG
Originally Posted by D C
OK, if you say so, but that is contrary to the linked info. A 91 LI load is 1356lbs, achieved at 36psi.
A fully loaded vehicle dead weight is 1350
It will likely fail
Must have a 10-20% margin for accel, both linear and angular, impulse (bumps), loss of strength due to fatigue, etc.
That is why MB REQUIRES 41
If you think advising people to run 36/36 on a 91 LI when MB requires 41/45 on an even higher 95/94 LI is sound advice you obviously do not understand
They are not pulling numbers out of their butt like you lol
Old 07-30-2014, 06:53 PM
  #52
-Marlin-'s Avatar
2011 C63 AW
I wish I'd seen this thread a couple months ago. I set the tires at the factory spec of 41/45 I think, which turned out to be 43/47 when warm. THAT SUCKED!
The tires were like balloons, the ride ultra stiff, and I got complaints from passengers. I discovered the gas door and went with a 38/38. Love it! Much softer ride and it just seems better all around.
Old 07-30-2014, 07:01 PM
  #53
Ingenieur's Avatar
C63 AMG
I ran mine at 41/45
Then saw the door flap 39/39, much better
The I noticed when CPO'ed the dealer put 245/265 vs oem 235/255
The LI's are much higher: oem 95/94 vs 97/97!
So to get the same load as oem 40/42 in the middle min/max I could set them at 37/36
I settled on 37/38 which is a vast improvement in ride and wearu
Old 07-31-2014, 12:36 PM
  #54
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Ingen is right on this - you do not want to under-inflate your tires. If you can figure out the actual vehicle weight and load and do the math for the load index, then all the power to you. Mercedes is always going to assume the worst-case scenario and add a 15-20% safety margin so that's how you end up with the high reecommended pressures on the fuel door. Having said that, a slightly over-inflated tire (while providing a harser ride) is much safer than an under-inflated tire which is prone to overheat due to the sidewal flexing and burst (Ford Exporer / Firestone issue). If in doubt, put more air in rather than less.
IMHO you're all very much overthinking this whole LI and rating thing. If you are running OEM tire sizes, put in what the fuel door says and just drive the damn thing. You bought a C63. If the ride is too harsh, buy a freaking Cadillac instead and stop with the moaning. But, just to add more fuel to the fire, not all "same" tires are the same. In fact, the OEM Contis or Yokos that come on the C63 are differnt than the regular Contis / Yokos of the same model/size. There is that little pesky "M0" suffix, which means they're made specifically to MB's specs that are different from the regular batches. Same goes for Porsche tires - they use the N-spec tires, which must meet more stringent standards than the identical regular production tire. The M0 tires do not list the actual load ratings - they only say that they are XL rated. Have fun with that one now...
Old 07-31-2014, 12:38 PM
  #55
Diabolis's Avatar
... until you put four people in the car, decide to show them just how powerful and fast it is and open it up a litttle, and you get a blowout at speed... yeah, definitely better.
Old 07-31-2014, 03:06 PM
  #56
Ingenieur's Avatar
C63 AMG
is the min ( 3 passengers + luggage) 38/38 on you gas flap?
are you on oem spec tires?
Old 07-31-2014, 04:21 PM
  #57
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
Is there any harm in running tires and/or pressures that exceed the load required for the car? I've always been carful to get enough, but never thought there was much of a downside to having a setup that exceeds the load requirements of the car.
Old 07-31-2014, 04:40 PM
  #58
Diabolis's Avatar
Provided that you don't overinflate the tires past their maximum rated pressure (usually 50 psi cold - it's somewhere on the sidewall) and the possibility that you may get somewhat uneven tire wear due to over-inflation, the anser is no. It simply means that your tires are able to safely support a heavier vehicle or load.
Old 07-31-2014, 05:29 PM
  #59
Ingenieur's Avatar
C63 AMG
Not safety wise
Ride will be harsher
Tires will wear in the middle
Handling will suffer, less contact patch and the shape changes from the lateral to the direction of travel
Old 07-31-2014, 07:05 PM
  #60
-Marlin-'s Avatar
2011 C63 AW
My gas filler door says 38/39 for light loads.
No chance of a blowout where I'm set at. If you wanna stay above 40lbs by all means do so, but I feel better at 38/38 and the tire wear is spot on. Most of the time, it's just me on a joy ride during the weekend. 43/47 warm is brutal on your fillings, back, and suspension IMO. I have a lot of bad roads around me. This car is meant for autobahn.
Old 07-31-2014, 07:09 PM
  #61
Ingenieur's Avatar
C63 AMG
38/39 is good for 3 people plus luggage
For only the driver plus a passenger it is fine
Quick Reply: Tire pressure adjustment for + sizes
