lowering rear
C 63 AMG PP
lowering rear
I have a 2008 C63 PP.
What I understood was that it has stiffer suspension, but is it also lower?
I want to lower the rear suspension by 1/2 inch , but I don't want softer springs.
Any sugestions?
I have 10x20 with 275-25-20 wheels/tires in the rear
Any sugestions?
C 63 AMG PP
8mm would be fine.
I have to find out if I can buy these through our dealer here.
Do you know what partnr it is?
Can I see or measure what pad I have now, even if it's still under my car?
Thanks!
Thanks!
you can see them when installed, but you need good light with the car jacked up and secured with the wheel hanging
if you do a search you can find the part number
edit:
A 210 325 01 84 - 5mm Spring Pad
A 210 325 02 84 - 9mm Spring Pad
A 210 325 03 84 - 13mm Spring Pad (this is what's on mine, 3 little '****')
A 210 325 04 84 - 17mm Spring pad
