Projector led xenon Facelift Style W204
Hello all,
I need help on my c63 amg, I would want installed new lighthouse(headlight) led xenon face topspin(lift) w204 but by making the connection I have only xenon which ignites, the indicator and the night light does not work! A somebody could help me found the good connection or has to see simply the plan.
Thank you for your answer
You are installing facelift headlights on a pre-facelift car?
If this is the case it is not a simple plug and play swap. You will need a new front SAM or an used front SAM coming from a facelift with xenons. Coding is involved as well.
I'm guessing you are not in the US and by the amount of dust/sand in the engine bay you might be living in Africa or middle east. Nevertheless you need acces to xentry for coding.
I installed the complete lighthouse(headlight) from mercedes " of origin " it makes xenon ect..., I am European of France.
ah t'es français quelle plaisir
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
année 2008 mon c63 amg,les xénon fonctionne ce qui ne marche pas ce sont les clignotants et les veilleuse j'ai besoin juste du schéma de branchement ensuite je la ramène chez Mercedes pour un codage.
