CF Wing Mirror Problem
2 Attachment(s)
Hi, I bought a set of CF mirror covers. However, I am having trouble removing the light strip off the original to transfer to the CF mirror.
It only seems to open on one side. Attachment 399897 The side seems welded lol. Attachment 399898 |
I just did this mod. Remove the two screws from the light strip. Undo the two clips. The ends of the blinker light strips are glued to the mirror cover. I gently pulled until is could separate the strip from the glue. A hair dryer helps.
See thread here: https://mbworld.org/forums/showthread.php?t=548224 |
OP, where'd you buy this from?
You need to remove the screws and heat up the middle part which goes into the blinker. It's glued on with double-sided tape.
^ This
Originally Posted by olszowa12
(Post 6127530)
Is it fairly easy to remove the lens on the 08-09 mirrors once the cover is off? |
Originally Posted by black lavender
(Post 6127846)
Matt,
Is it fairly easy to remove the lens on the 08-09 mirrors once the cover is off? Yes, it's just screws and double-sided tape. Very easy, just ne careful no to break any brackets. |
