C63 AMG (W204) 2008 - 2015
Esp, abs inoperative
Old Aug 14, 2014 | 05:31 PM
LFM_Vancouver's Avatar
C63s now in the garage. Sold-GLA45 AMG Edition 1, Sold-2010 Mercedes C63
Originally Posted by Youngin
Its not throwing any codes or check engine light
Was your car under warranty
My car had 48 hours of warranty left when this happened. So all new computers and all headbolts done under warranty.
Old Aug 14, 2014 | 05:52 PM
Youngin's Avatar
10 c63. 12 f250
Originally Posted by tfthach13
Have you tried the brake sensor as I suggested??
It worked for me when I had this problem...
Pad wear sensor I ordered 1 should have it tomorrow.
Also a question did your steering wheel get stiff after a sec of driving along with all the lights abs, esp ,run flat etc
Old Aug 15, 2014 | 11:02 AM
tfthach13's Avatar
'09 C63
Yes. Especially at lower speeds. At higher speeds it wasn't as noticable but I could still feel powersteering not as smooth as it was before.
Old Nov 17, 2014 | 01:01 PM
FBBC63's Avatar
2010 c63 sedan
Did the brake sensor work for you? My dealer is telling me its the Control Module.. $1600!!
Old Nov 18, 2014 | 07:17 AM
Steve Richo's Avatar
2013 ML 350 Bluetec
Originally Posted by 604 C63
Battery. Seen it on 3 cars. At about 4 years these AGM batteries just go. You don't have enough juice to run all systems.
I had the same problem a couple of months ago, turned out to be battery and the regulator.............
Old Oct 5, 2016 | 06:00 PM
Mercker412's Avatar
2008 Mercedes C63
Sorry to bring up an old post about this, but @FBBC63, did you end up replacing the control module? I am being advised the same thing and it is not cheap!!
