C63 AMG (W204) 2008 - 2015
Winter Tires
Old Sep 15, 2014 | 08:36 PM
rmt52's Avatar
2016 C63 S, 2011 C63 R.I.P.
Originally Posted by tabrak
Blizzaks wear and becomes normal winter tires. Michelins stay ok overall. Nokians are way better. This winter, I'll try the new hakkapeliitta r2 in the back.
they were absolutely useless for me if there was more than an inch or two of snowfall (not in atl). ended up driving my buddy's range rover instead.
Old Sep 16, 2014 | 12:39 AM
papashango's Avatar
This and that.
So confused between the Michelin's and Blizzaks now....keeping in mind there is tons of snow in Alberta!
Old Sep 16, 2014 | 12:54 AM
CarHopper's Avatar
E63S | X5
Read up on the Michelin Ice tires. I think I am going to try these.
Old Sep 16, 2014 | 10:26 AM
chrisridebike8's Avatar
'10 C63
Originally Posted by coladin
I think it may be a terminology thing but for us up here we have winter tires. I know some here say "snow" tires and talk about studs or chains, but those are illegal here.
They are a performance winter tire as the low profile dictates that there will be compromises. If we could put something with a higher profile it probably would help. I had the LM32s on my G37X and the LM60s and they are very good at first, but due to the high wear rate of the suspension setup, I just go with them anyways, as the Michelins, I think, are more expensive.
I just looked for what I thought I read last year. I think I might be wrong now. When I researched, I thought the LM-32s were for cold, wet days with the ability to get you through some light snow (eg-it starts snowing while you are at work and have to drive home) but weren't meant for going through severe snow (eg-a ski trip into the mountains). The compound was different in order to help with cold, dry traction/handling when compared against their more dedicated (what I called) "snow" tires like the WS-series. In any case, I can't seem to find anything saying snow tires are different than winter tires.
In my opinion, however, what tire you choose is dependant upon the type of winter driving you do, just like with any tire choice. Are these tires for you to bring your pregnant wife to the hospital in your C63 during a blizzard? I would go with the tire that has the least comprimises for snow performance. Or do you have another vehicle you plan to use in the snow, and these tires are for simply better traction in cold and wet conditions with the occassional trip home through light snow? In that case I would get a performance snow tire. As stated above, "performance" snow tires will have some compromises. For me, in the winter I am willing to give up quite a bit of dry weather performance in order to make sure I don't get stuck.
Old Sep 16, 2014 | 11:45 AM
coladin's Avatar
2014 C63 507, 2012 R350
Um, yeah, my wife's car is a little bit different than yours lol. We have the R Class for all the mundane, hockey chores in the inwter and my car essentially is my daily driver to do my thing. Blizzaks do a very good job, I would recommend them especially when new. Off throttle, the C63 is like a pitbull, responding to directional change well controlled and grippy, of course with the nannies all on., Blizzaks have that sticky compound and are soft so they are a very good tire. Relatively quiet too.
Big issue with the 63 is ground clearance, I got beached last year due to the amount of snow I tried to drive through, but got out with a brake torque launch, this is amazingly efficient. Better than when I put the wife and three kids in the trunk, not joking!
Old Sep 16, 2014 | 11:47 AM
coladin's Avatar
Don't worry, both are excellent, you would be fine in either!I have driven 4 winters in both of my C63s and we had a lot of snow last year.
Old Sep 16, 2014 | 12:43 PM
  #32
papashango's Avatar
This and that.
So which Blizzak's then? LM or WS? I am going to the dealer today after work, I will get their input as well and get a few quotes.
  #33
Mort's Avatar
Don't wait too long. Some winter stock runs out early.
Old Sep 17, 2014 | 11:50 AM
  #34
papashango's Avatar
This and that.
Checked with the dealer yesterday and he wasn't specific about which tire exactly but he said Pirelli and Michelin is the way to go. For Pirelli he quoted $560 per tire and Michelin $450 per tire. lol.
Old Sep 17, 2014 | 11:56 AM
  #35
coladin's Avatar
Tire RACK!
Old Sep 17, 2014 | 02:43 PM
  #36
papashango's Avatar
This and that.
I am going to try my local non-dealer guy and if that is bad then tirerack route I shall go.
Old Sep 17, 2014 | 02:51 PM
  #37
coladin's Avatar
Blizzaks right now are 720 USD for a set of 4 on Tire rack. I don't think you will find better after duty, delivery.
Old Sep 17, 2014 | 04:42 PM
  #38
alexmtl's Avatar
2013 C63 coupe P31
WS !
Old Sep 17, 2014 | 05:07 PM
  #39
CarHopper's Avatar
E63S | X5
I saw it in here, but I'll ask anyway.
People with blizzaks, did you notice pretty extreme tire wear? I've read around that on dry roads in these cars the rears will really wear down and you might get a season out of them. I'm in a place that has good plowing so more often then not I will be on dry roads and would like something I can go through 2-3-4 seasons with.
Old Sep 17, 2014 | 06:18 PM
  #40
papashango's Avatar
This and that.
Good question! Interested in finding that out as well! I don't wanna have to replace them every season either.
Old Sep 17, 2014 | 06:51 PM
  #41
coladin's Avatar
My rears lasted 2 winters, about 8k miles or so
Old Sep 17, 2014 | 09:25 PM
  #42
zibby43's Avatar
'20 GLC300 SUV
The LM-32s are definitely suited for snow. They are high performance winter/snow tires that also perform well in cold/wet and cold/dry conditions (in addition to snowy conditions).
I had the LM-32s mounted for the worst winter in our State's history and they performed better than any other snow/winter tire I've used.
Old Sep 17, 2014 | 10:14 PM
  #43
Ingenieur's Avatar
C63 AMG
Make sure you get the proper load/speed rating
Spec is 92V XL
Also even in AK you're on pavement most of the time, the tires will wear quickly
Old Sep 21, 2014 | 01:01 PM
  #44
Saschi's Avatar
C63 AMG Coupe
225/40/18 front / rear
Continental Winter Contact TS830P
Old Sep 21, 2014 | 01:29 PM
  #45
AMGangster's Avatar
2010 C63
Go for the WS80. I tested them and it was a noticeable improvement over the WS70 and the X-ice Xi3. Plus they now come in a H speed rating.
Old Sep 21, 2014 | 02:57 PM
  #46
alexmtl's Avatar
2013 C63 coupe P31
I rotated my tires every season and at my 3rd season I sold my car, so I don't think they have *extreme* tire wear. However the WS80 are VERY soft (which I guess is why they work so well on snow), so there's a good chance they last less than a performance winter
Old Sep 22, 2014 | 01:56 PM
  #47
jdbassman's Avatar
2011 c63
I ran Nokian Hakka 235 all around and they were simply awesome.
If the car can clear the snow (height), there wasn't anything in the way.... these tires are great!
Old Sep 22, 2014 | 01:57 PM
  #48
ToXicXxX's Avatar
2011 C63 AMG P31
I live in Calgary and use nokkian Hakka 7 studded.
255 rear 235 front.
Old Sep 29, 2014 | 04:54 PM
  #49
papashango's Avatar
This and that.
^How do you find them in our winters?
I will most likely do a square set up. I was confused between the two Blizzak's and the Michelin, but now you've thrown another one in. lol
I am thinking Tire Rack is going to have the best prices so will order from them most likely. I guess they are all good and the best priced one should be a safe bet?
Old Sep 30, 2014 | 11:41 PM
  #50
peh-amg's Avatar
'13 Audi RS5
I've got a set of 18" winter wheels and tires for sale. Dunlop Winter Sport 3D's 235/40R18 XL 95V mounted in MSW 19 x 8" Type11 rims including TPMS sensors and lug bolts. Lots of tread left. Great winter tires - I ran them on the two C63's I used to have and was very happy with them.
email me at h54913@yahoo.com if interested
