DIY - Paddle Shifter Replacement
I've tried it, doesn't work. I know exactly how to do it. But I lack the proper tools apparently. The pin is pressed in hard. I need ideas on what else can be used.
Received 2,811 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
There's no special tool. It presses out from one side. Maybe you're doing it on the wrong side. Or you need to press harder. There is no magic tool which will make this easier for you. Everyone presses it out with a little screwdriver, or a nail, or a small dowel, or maybe a steak skewer from the kitchen drawer. You get it. Something metal and small that can press it out.
From my experience screwdrivers don't work as well. Use the handle side of a 4mm Allen key wrench, it's flat sided so it will press the pin a lot easier. Make sure it's at the correct 45 degree angle. The pin will release and the air bag will pop out, be careful of the wires and make sure you don't pull on them.
Mag1c Carp3t (03-25-2016)
He's talking about the pin to remove the paddles from the electronics
