C63 AMG (W204) 2008 - 2015
Check engine and engine rattles
Old Dec 8, 2014 | 08:31 PM
snowmuch's Avatar
C63 AMG
Originally Posted by Ingenieur
You replaced all coils including 7 and 8?
And they still misfire?
Probably not coils
Did the other codes go away? Steering, intake heater etc ?
Smoothed out with maf disconnect but still lumpy
New filters? Cleaned?
Try it w/o the filters, not drive, just idle
We swapped the 7,8 coils with 3 and 4 and still getting misfire on 7 and 8. I didn't look at the codes but I think others went away. Will try with new filters and new MAFs tmr.
Old Dec 8, 2014 | 08:54 PM
Ingenieur's Avatar
C63 AMG
Sounds like it might be drying out?
Old Dec 8, 2014 | 08:57 PM
snowmuch's Avatar
C63 AMG
With with MAF connected it sounds like its suffocating and cars will shuts off due to too many misfires. With MAF disconnected it sounds just very shaky.
Old Dec 8, 2014 | 09:09 PM
Ingenieur's Avatar
C63 AMG
Did you notice any moisture on the coil or maf connectors?
Did you clean/dry them before reconnecting?
Old Dec 8, 2014 | 09:17 PM
snowmuch's Avatar
C63 AMG
There was burst of moistures when I was unscrewing the coil but the inside is clean and dry.
Old Dec 8, 2014 | 09:20 PM
ToXicXxX's Avatar
2011 C63 AMG P31
The coils were bone dry, no dielectric lube left on them. Plugs 6-7-8 were soaked in gasoline (which makes sense with the misfires), others were extremely worn out. Code P0010 appeared sporadically (indicating a possible failing cam solenoid). After plugs and coil swap, only 7/8 were giving codes as well as "random misfires".
It was actually misfiring so bad it would stall, on several occasions. Looking at a few possibilities...
Old Dec 8, 2014 | 09:24 PM
  #32
snowmuch's Avatar
C63 AMG
Originally Posted by ToXicXxX
The coils were bone dry, no dielectric lube left on them. Plugs 6-7-8 were soaked in gasoline (which makes sense with the misfires), others were extremely worn out. Code P0010 appeared sporadically (indicating a possible failing cam sylenoid). After plugs and coil swap, only 7/8 were giving codes as well as "random misfires".
There is a bunch of people having cam solenoid problems in their c300 not sure it shares the same part with c63
https://mbworld.org/forums/c-class-w...-campaign.html I member lone star doing the same thing with my tail light and engine wiring recall.
Old Dec 8, 2014 | 09:30 PM
  #33
Ingenieur's Avatar
C63 AMG
So everything cleared up but misfires on 7 and 8 + associated random
You eliminated the plugs and coils as the issue
And a random a cam code?
Try cleaning cam sensor and solenoid connectors?
Just seemed like a lot of water in the airboxes
Perhaps the random steering, heater, etc codes were generated when voltagecwas cut due to the misfires?
Sounds like you got a plan
Let us know what you find
Old Dec 8, 2014 | 09:37 PM
  #34
ToXicXxX's Avatar
2011 C63 AMG P31
I believe those are old collective codes, his car hadn't been cleared in a long time.
We can pull and clean the solenoids (similar to BMW VANOS cleaning), but, theres a few angles of attack here.
We will attempt testing my spare MAF sensors tomorrow and see what that yields.
It doesn't seem the parts are shared between the C63 and C300, at least via partnumber.
Old Dec 8, 2014 | 10:06 PM
  #35
PeterUbers's Avatar
Man, I wish I knew as much about engines as you guys, I'm impressed!
Old Dec 8, 2014 | 10:23 PM
  #36
ToXicXxX's Avatar
2011 C63 AMG P31
Eh, for me it was a hobby turned job! Let folks like us tackle that crap for you!
Old Dec 9, 2014 | 12:31 AM
  #37
papashango's Avatar
This and that.
Haha have to agree with Peter. Most of this jargon sounds like French and is flying over my head. Another reason I don't want a car without warranty. lol Thankfully there are guys like Toxic around who can deal with this sorta stuff for us lol.
Old Dec 9, 2014 | 02:09 AM
  #38
Merc63's Avatar
C63 AMG
Sounds like a fueling issue and not a cam issue. Plugs soaked with fuel, runs better with maf unplugged...
Cam would cause issues on the whole bank.
Try new o2 sensors and make sure plugs are good.
Old Dec 9, 2014 | 07:33 PM
  #39
ToXicXxX's Avatar
2011 C63 AMG P31
O2 sensors would also be a bank issue, not individual cylinders.
If you look at the firing order on the M156 it is 15426378. The 7-8 misfire is the end of a complete cycle. Perhaps there is some merit in that.
Old Dec 9, 2014 | 07:38 PM
  #40
Merc63's Avatar
C63 AMG
Not necessarily. I've seen misfires on just a few cylinders when others will Fire.
Old Dec 9, 2014 | 07:46 PM
  #41
ToXicXxX's Avatar
2011 C63 AMG P31
Fair enough. I've never encountered an O2 sensor giving issues without generating a code.
Old Dec 9, 2014 | 07:49 PM
  #42
Ingenieur's Avatar
C63 AMG
Let's summarize
New plugs
Coils swapped so not coils
Only codes are misfire 7 & 8 plus the associated multiple code
All others cleared
Where are cylinders 7 & 8 physically located? Rear most driver side?
Do 7 & 8 random or consistently misfire?
Do they misfire with the maf disconnected?
Was the fuel tank run low or dry?
Plugs are wet so it is fueling correct?
Did you check for spark?
Did any of the 'mud' get downstream of the filter?
Old Dec 9, 2014 | 08:54 PM
  #43
ToXicXxX's Avatar
2011 C63 AMG P31
Let's summarize
New plugs
All others cleared
7&8 are by the firewall on the drivers side yes.
No mud downstream, though we can't tell for sure without removing the IM.
Next step is a compression test to see if everything internal is healthy.
Curiously the fuel injector on 7 was slightly deformed around the outer housing. Nothing major, but. Notable fact.
It runs slightly better with no MAF, but testing a spare set of air boxes and MAF's yields the same results (and those MAF's work fine in my car).
Old Feb 26, 2015 | 12:15 AM
  #44
SROC276's Avatar
2010 C63 P31 AMG
Just curious? What was the final result?
Old Feb 26, 2015 | 04:27 PM
  #45
snowmuch's Avatar
C63 AMG
It was the lifters. I had the entire engine swapped to a facelift one with no lifter or head bolt problem.
Old Feb 26, 2015 | 06:23 PM
  #46
SROC276's Avatar
2010 C63 P31 AMG
Goti it....thanks for posting
