C63 AMG (W204) 2008 - 2015
FS: HRE P101 C63 BS fitment
Old Feb 15, 2015 | 04:00 PM
  #51
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
^^ LOL I don't know what u are waiting for Anthony. 19's look too small on the BS, 20's looks perfect
Old Feb 15, 2015 | 04:40 PM
  #52
NellyRod's Avatar
2012 C63 AMG BS, 2010 DUCATI 1198S
Originally Posted by abcut973
I had to come back to this thread and check the wheels again and again ....
They would look soooo sick on your car ;-)
You could also have HRE refinish them however you like. Jus sayin. Lol
Old Feb 15, 2015 | 09:28 PM
  #53
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
How much do they weight?
Old Feb 16, 2015 | 12:15 AM
  #54
carlssoncclass's Avatar
Hi there,
Is this still available? And let me know if you are willing to ship to Shanghai, China. Thanks in advance. I can pay for the shipping fees.
Old Feb 16, 2015 | 01:40 AM
  #55
NellyRod's Avatar
Originally Posted by carlssoncclass
Hi there,
Yes still available. PM me the shipping address and I'll try to get you a quote. I'm afraid international air shipping will be costly though.
Old Feb 16, 2015 | 02:06 AM
  #56
Private Message sent, please check. Thanks :-)
Old Feb 16, 2015 | 02:58 AM
  #57
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
man ...for 3000 im sold. checked fitment with my peeps and wont be able to fit neither of my cars ...
good luck with sale at this HOT price
Old Feb 16, 2015 | 03:46 AM
  #58
604 C63's Avatar
2012 E550 Cabrio
Would a fender roll do it on a regular c63 sedan? or are they just living in an entirely seperate world?
Old Feb 16, 2015 | 08:07 AM
  #59
Kriston's Avatar
C63 AMG
I Just re-barreled a set of S101's. For a stock body C63. They were originally 11.5 wide in the rear and 8.5 front.
The offsets in the front of Nelly's set just wouldn't work for the Normal body C63's. Even if you re-barrel, you will have to drop the front widths down to 8 inches total to make it work with an ET24 offset.
Nelly is practically giving them away at this price.
Ab im not sure what else you need man, these are the wheels for you. This set is 10K easy.
Old Feb 16, 2015 | 08:23 AM
  #60
Roswell's Avatar
Trust me bro they would be on my car already if the fitment would be compatible with the regular C63 lol
Makes me want to buy a BS cuz those looked perfect on Nelson's car. I really like the brushed & tinted clear outer lips, very unique.
Old Feb 17, 2015 | 02:27 AM
  #61
Im planning to do a custom BS widebody on my c63 sedan, and I will widen the oem fenders with sheet metal or fiberglass. Anyway, will these HRE S101work? Thanks in advance.
Old Feb 17, 2015 | 02:37 AM
  #62
dchl21's Avatar
yes do it
Old Feb 17, 2015 | 08:20 AM
  #63
VaclavSV's Avatar
2012 C63 AMG Black Series
yes do it
I dont think the rears will work because of the different rear axle on the BS compared to the Sedan.... I might be wrong though..... Thats why when Criager did his conversion he went with Rennen's
Old Feb 17, 2015 | 08:57 AM
  #64
Roswell's Avatar
^^ bingo! The BS has the E class rear axle so these wheels won't work unless u replace the axle.
Sajun, what are u waiting for to PayPal Nelson? Lol
Old Feb 17, 2015 | 03:25 PM
  #65
NellyRod's Avatar
I didn't weigh the wheels alone but I weighed them with Michelin PSS on and compared them to the OEM 19's with Conti's. The fronts were 3 lbs heavier than OEM and the rears were 2 lbs heavier. Keep in mind these are wheels and tires combined that are being compared. Also keep in mind the HREs are bigger and wider, as well as the tires. On a 500+HP car, this isn't very noticeable. The one thing that was noticeable was the loss of traction when I put the OEM wheels and tires back on. I took to the canyons in Southern California as I normally would, and my ESP was kicking in way too often. This car needs 265 fronts and 295 rears. The stock widths don't cut it.
Old Feb 17, 2015 | 07:33 PM
  #66
dchl21's Avatar
my bad
Old Feb 18, 2015 | 03:14 PM
  #67
abcut973's Avatar
You'll need E class rear axle!
The retrofit is possible as DadC63 did it on his.
Correct Meng
Thanks Nelson!
So we are probably talking about 24lbs/wheels
Old Feb 18, 2015 | 07:28 PM
  #68
pjdizzle94's Avatar
2011 bmw 335i, 2014 c63
hmmmm i could buy and rebarrel... I'm local too...
Old Feb 19, 2015 | 11:14 AM
  #69
Kriston's Avatar
C63 AMG
The front and rears will require a re-barrel.
Those lips are 2.5 Inches if I remember correctly. Re-barrel the rear with a 7.5 inch inner barrel and the front will need to be done with a 5.5 inch inner barrel. even if you re-barrel the front it doesn't change the offset. Its still low on the front.
You can shave the back pad, but you will only get 4MM out of it. You can make it work, but will have to do some experimenting with tire sizes, MAYBE you can fit a 215 / 30 / 20 upfront with those offsets on a normal body C63.
I have no idea how any of these BS owners haven't jumped on this deal.
Old Feb 19, 2015 | 11:47 AM
  #70
R8lai's Avatar
C63 BS & Speciale
Because the stock wheels is good enough already
Old Feb 19, 2015 | 02:31 PM
  #71
NellyRod's Avatar
You're right. The stock wheels are good enough, but not great. They're not wide enough to gain the advantage of putting wider tires on a car with this amount of power.
Old Feb 19, 2015 | 02:35 PM
  #72
NellyRod's Avatar
Correct Meng
Thanks Nelson!
That sounds right on the high side. You could shave a lb with titanium hardware from HRE. You could also shave another lb using tikore lugs.
Old Feb 19, 2015 | 02:42 PM
  #73
abcut973's Avatar
How about hiding the hardware? Can HRE do it?
I've never been a fan of 3pcs wheels because of that.
Old Feb 19, 2015 | 07:31 PM
  #74
Mort's Avatar
I don't think you can hide the hardware without re-cutting the centers. How else would you hide the holes? You could perhaps get the fasteners painted black to match the centers and thus making them hard to see and so they don't stand out and draw so much attention. The difficulty might be in getting a finish that would be durable and not chip off when the fasteners are tightened.
Old Feb 19, 2015 | 08:42 PM
  #75
abcut973's Avatar
ADV offers an option to hide the hardware. I don't know how does it work but looks like they can do it
