Benefits of stainless steel braided lines??
They are also more corrosion resistant and have a much broader heat range than what your OEM would have meaning they will stay how they should if you are tracking heavily.
You probably won't find anything out there other than Renntech and the ones that we make unless you custom make your own.
Ours sell for $199 for the car set and I have them in stock if you are interested.
But again, not on the amg. Just personal experience on the difference.
On a track car, there may be some brake modulation feel benefit as the s/s braid prevents the fluid hose inside from expanding (bulging) under high brake fluid pressures. However, this is only evident on cars where the OEM lines are made of relatively soft rubber, and the ones on the C63 are internally reinforced so there is no difference in feel. I have a set on mine and I've been driving numerous other C63s back-to-back on the track and have never noticed a difference.
You have to be careful with s/s brake lines because some of the cheaper ones have been known to pop the hose from the collar / fitting that is crimped on, which is about as dangerous as things can get at the track (line pops out from caliper and your brake fluids squirts out leaving you with no brakes). I don't know who makes the ones that ACG sells, but I - and a lot of professional racing teams - use Goodridge. They'll be happy to custom make whatever lines you need if you give them a call. Stay away from cheap no-name brands. Again, I am not in any way saying that the ACG ones are not high quality lines, only that you need to be careful what you buy if you are in the 0.1% of serious track junkies that can possibly see some benefit from them, especially on a C63 where the OEM ones are heavily reinforced.
