Replacing rotors and brake pads
I am curious mostly about t he difference in looks between the two. Can someone post pictures of what a 2 piece rotors looks like vs a one piece? I am trying to see how it would look on the car if I went with a one piece instead of 2? Thanks!
No the calipers are the same between the C63. models. Only difference is the color
Anyway, C63 brake pictures to clear up the confusion:
P30 Rotor - Two piece. Part #2194210212, about $900 each. Note the screws that show the hat is separate from the disc. You can't buy just the discs though (thanks Mercedes).
P31 (also 507) Rotor - '1.5' piece. part #2124210512, also about $900. There are no screws and the "spokes" of the hat are cast directly into the disc.
One Piece Rotor found on the vast majority of C63s. Part #2044211212, About $150 each. You can see all the extra mass vs. the p31 rotors, but then again p31 rotors are 6x the price.
Notice that the caliper is the same for all of them, and that you probably can't tell the difference with the wheels on as most of rotor will be covered by the wheel.
Rear brakes are the same on all C63s, part #2044230412, about $200 each.
Notice that the caliper is the same for all of them, and that you probably can't tell the difference with the wheels on as most of rotor will be covered by the wheel. Rear brakes are the same on all C63s.
Perfect! Thank you for the clarification and pics. Cheapo (if you could call them that) rotors it is for this 507!
Top photo = Pure Sex
Middle photo = Meh
Lower photo = Boring
its an AMG, you know going in that parts aren't going to be cheap.
i'll likely buy 2piece when required on my p30 be it aftermarket or oem simply to stick with what came with the car.
and there really is quite a visual difference in that picture, the p30 two piece has a much cleaner look which could come into play depending on your wheels
yes we all know it's an AMG, doesn't mean I'm willing to **** money away on 18 pound less unsprung weight in which i can't even feel.
Once again, subjective. the one piece looks fine to me.
I figure I won't be replacing rotors all the time so i'll opt for the pricer solution without much worry and shop around for a better deal. If i put one piece on i'd end up putting 2 piece back before i sold the car anyway
it's all about choices and thankfully there is an option
