C63 AMG (W204) 2008 - 2015
19" Staggered 43mm S Class Black Style wheels
Old 02-17-2015, 09:28 PM
Former Vendor of MBWorld
powerwheelspro's Avatar
E320
Description: 19" Staggered S Class black Style wheels
WHEEL SPECIFICATIONS
Price: $699
Offset: 43mm
Weight: ~28lbs
Hub size: 66.6mm
Bolt Pattern: 5x112mm
Finish: Black
Shipping: $85
19" Staggered 43mm S Class Black Style wheels-20150210_081800_zps1vihcprb.jpg
19" Staggered 43mm S Class Black Style wheels-20150210_081751_zpsy5iu4ptb.jpg
19" Staggered 43mm S Class Black Style wheels-20150210_081827_zpsb3apxmi9.jpg
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards.
Manufacturing Defect Warranty: The wheels are made in a low pressure casting process like OEM wheels and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels will work with your TPMS sensors and you can use your stock lug bolts. New chrome ones are available for $20 for the set of 20.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
Quick Reply: 19" Staggered 43mm S Class Black Style wheels
