Suspension Problem someone please help!
I had installed H&R coilovers around a year ago and drove around 10,000 miles. Last weekend due to drifting a lot my tires shredded its last tread. Anyways after replacing my continentals with pirelli pzeros 265/30 zr 19 i noticed that the right rear wheel was lower than the left side which led to an immense amount of rubbing on the right side. My service was up and asked one of the mercedes technicians to lift the right side up since my coilovers were unbalanced. After receiving my car still rubs but not as much as it used to before it only does on speed bumps or if i have more than 2 ppl in the car.
Does anyone know what could be the issue? I would really appreciate your help!
Is their a way of tightening the springs? maybe one could be tighter than the other?
THANK YOU
THANK YOU
2014 C63 AMG 507 sedan
AFAIK, H&R coilovers are only height adjustable. Did you buy it new or used? Any clunking or weird noises? Check if the coilover is blown. Signs of leaks, oil residue on the shock body, etc.
