Mobil Jet oil
Hello guys
There any chance i could use oil from aviation ? seems it very stable at high temperature..... http://lubsboutic.co...IL-1-JET-OIL-II |
I wouldnt. That stuff requires seals and things to be of a certain grade or it can eat them. Stick with automotive oil.
Are you for real??? With two souped up cars in your garage judging by your siganture, I would think that you would at least have a rudimentary idea of what oil does and what are the lubrication requirements of an internal combustion engine and an oil designed to lubricate jet turbine engines. If you want the specs, they are here - http://www.exxonmobil.com/USA-Englis...et_Oil_II.aspx. You might as well put lavender oil with a touch of coriander in your crankcase as it will at least smell nice for the first 2 minutes before the engine seizes. You have spent money on two souped-up cars, you know how to post here so can obviously type and use the Internet, but you can't spend 10 minues of your time and do a Google search on engine oil basics? Try this: https://answers.yahoo.com/question/i...QuChp&submit=y or Google "jet oil in cars". And, I gather this must have been written about you: http://jalopnik.com/5938552/why-you-...el-in-your-car.
I really can't believe that people that are (car) entusiasts can actually be THAT ignorant about the objects of their enthusiasm. :wall: |
I use that stuff every day at work, the detergents in it will DESTROY seals and burn. I highly discourage this idea.
I use it too, even in the car... to lubricate hinges and latches. :)
Unfortunately, money doesn't always equals brains. :smash:
2 Attachment(s)
Mobil Jet Oil II is factory specified in AMG's IHI-sourced superchargers.
Sure wouldn't use it in the sump, though. :crazy: Attachment 390967 photo credit kjlindgr Attachment 390968 |
^^ Interesting. Never knew that.
Originally Posted by splinter
(Post 6363582)
Sure wouldn't use it in the sump, though. :crazy: <pics removed> |
Originally Posted by alpha26
(Post 6360629)
Hello guys
In Nam we had problems with people stealing our oil for turbine engines in Hueys etc.
They would use it to cook with. Killed a lot of them. The stuff was watery thing but slick. Cans rusted through from moisture, stored in metal lockers, in the air because it did not handle moisture that well. Seals for the oil different were composition the dyno oil. Things have changed a lot but I would just buy Redline or one of the European Ester based synthetics. Mobil One which only some has some real synthetic cost are nearing what full ester based oil costs. |
I was very surprised how some people on here were rude to the OP. I think he asked a reasonable question and some people nicely told him not to use Turbine Oil because of the detergents reacting poorly with the seals. That was the right answer, but there was no reason for other people to say the OP was stupid.
In fact, I could be just as rude to the poster that said the supercharger is a turbine. Not true, superchargers are either a roots blower, a Lysholm screw compressor, or a centrifugal compressor, but it is never a turbine. A turbine is the opposite of a compressor. A compressor takes power to increase the pressure of the air going through it. A turbine makes power from higher temp/pressure air going through it and expanding/cooling it. :eek: |
Originally Posted by glennhl
(Post 6367199)
In fact, I could be just as rude to the poster that said the supercharger is a turbine. Not true, superchargers are either a roots blower, a Lysholm screw compressor, or a centrifugal compressor, but it is never a turbine. A turbine is the opposite of a compressor. A compressor takes power to increase the pressure of the air going through it. A turbine makes power from higher temp/pressure air going through it and expanding/cooling it. :eek: The OP wasn't asking whether one particular brand of oil is better than another, or the relative merits of one formulation over another. That would have indeed been a much diferent and more productive discussion. No, he asked if he could put jet turbine oil in his cars because someone told him it was stable at high temperatures. Now, by his very participation on this board, he is a car entusiast at the very least - not someone's grandmother who might have mistaken the windshield washer fluid filler cap for the coolant overfill tank. It is no different from, say, an experienced tennis player asking if he could use golf balls instead to play tennis because he heard they were smaller, ligher and easier to hit with a big racquet. Yes, I do hold the OP with his massaged and souped up cars (or the experienced tennis player) to a SLIGHTLY higher standard than the grandmother who has never seen what's underneath the hood of the car, so I do expect some level of basic knowledge about cars (or tennis as the case may be). Seeing as cars are something he is presumably passionate about and furthermore he is not stupid because otherwise he would not have either of those two souped-up cars, I do indeed expect people to spend 10 minutes of their life to learn a little bit about thier own passions and use a search engine (or God forbid, read a book) for the answer to a rather rudimentary question instead of asking everyone in a public forum to spend their time and just give them the answer. It is extemely rude and unfair towards people like you and I who do spend our discertionary time on the board helping others (and being helped ourselves when we need it) by asking a question that only a six-year-old would entertain for more than a few seconds. So, seeing as we are all car enthusiasts on this board, where do we draw the line? At what point do we say "sorry, but this is over the line and you need to do some basic research on your own first"? When someone asks if they can crazy-glue a Toyota wheel on their C63 because they got a flat tire right across a Toyota delership and the Toyota wheel that they can buy there won't bolt on? When someone asks what command they need to use to tell the car to turn left? As for the turbine, you are abslutely correct - a supercharger is not a turbine in the strict English sense of the word as it doesn't extract kinetic energy from a fluid flow, but rather uses kinetic enregy to create fluid flow. In effect, it is a turbine operating in reverse. My apologies for my mistake - English isn't my first language, and in my native one the term "turbine" does in fact mean a device that converts kinetic energy to/from fluid flow, but the direction itself is irrelevant. In English, when operated the other way it is indeed a compressor, in the same way that an electric DC motor is a generator when operated the other way but they are given different names despite the fact that mecahically they are the same device. Sorry for the mistake and thank you for the correction. |
Originally Posted by Diabolis
(Post 6367564)
If you are referring to my post, since when did it become poilitically or socially incorrect to call a spade a spade or in this case someone's gross ignorance just that? When this this become a kindergaten where the kids' fragile ego are so precious that it is forbidden to tell them that they're are miserably failing at somethign and that they really need to pout some thought into it?
To blast the op for asking (what is in your opinion) a dumb question, to only then follow-up with a venom-laced answer sure calls to question what your real issue is. I'd recommend having a trip to the rest room for a yank or two. :y |
Originally Posted by Rob CL
(Post 6367584)
Just as it may have been wise of you to place some thought into the fact you weren't born with what knowledge you posses, including a rudimentary grasp on spelling and couth.
(Post 6367584)
