*C63 AMG EXHAUST SOUND THREAD*
sick videos .. what else is done ? just LTH / tune / catless x pipe ?
fast c63 man
There are four diff C63s in the vids, mods ranging from MHP tune and LTs with off-road X pipe to one with a thermostat and another with thermostat and CF ram air inlets. My car is setup with the tune, headers and X, thermostat and CF ram air inlets and it's a BEAST.
C63 MBH - Agency Power - YouTube
IT SOUNDS SO GOOOOOOD, cheers man
The best I have heard is long tubes (deleted primaries) with deleted secondaries (straight pipe in place of secondaries). Everything else stock (stock resonator, stock mufflers). This maintains the AMG "bark" and sounds downright EVIL on partial and especially WOT.
However I am looking at getting a set of Wiestec LTH's, downpipes and catless mid pipes. Many of the LTH vid's sound like they add quite a bit of rasp and raise the tone. I like the idea of more power, I would like a little more sound, I don't want to change the sound significantly.
The car already has difficulty with wheel spin with existing power when you mash the loud pedal, so really, other than dyno numbers and the fun of doing mods.
So two questions:
What would people say is the biggest payoff for LTH's?
Are all LTH's raspy to a degree? If so how are Weistec?
So two questions:
What I want to try is replacing the stock resonator with an X Pipe or a different resonator to bring down the rasp and deepen it, if anyone has suggestions.
Stop tinkering with x-pipes, etc. in your car or assembling a complete system (unless the weight of the car is important to you when racing, in which case use titanium).
The best sound and performance on an M156 is obtained by installing Long Tube Headers (no matter what brand), 200 cell sport catalysts, original middle silencer and original rear silencer.
If necessary the catalytic converters can be left out. But the middle and rear silencer must stay in place! This is the only way to get the typical AMG sound. Do not be fooled by videos.
This combination sound the best!
If I was to do it all over again, I would just buy the VRP (as they are only 700 bucks) or Armytrix ($950) cat delete pipes and be done with it. Have some 200 cell cats welded in if you want to kill the smell , car doesn't even throw a cat code on mine with the 200 cell cats and a rear O2 spacer. You can also buy the Amrytrix pipes with 200 cell cats in them but for 2 grand you are much cheaper to buy 100 bucks in cats and have them welded in yourself. I have never tried an X pipe but most recommended against it as it changes the sound and not for the better, do an H or straight all the way.
Your car will sounds like a monster for 1000 bucks and if you want it even louder go full headers any brand.
